Sponsored by: Real Truck
Stupid leveling kit questions...
Old Feb 6, 2012 | 09:38 PM
Psyclopse's Avatar
Psyclopse
Something tells me these questions will be pretty dumb, and at my age I should be able to have figured it out. I did come from older 4x4's where leveling kits aren't the norm, so...
1) We all know lift blocks on the front are bad. Evil. Unsafe. Etc. I've accepted that as fact over 20 years ago. But what I can't figure out for the life of me is how these mini spring packs in the leveling kits aren't just glorified lift blocks. The springs don't appear to be long enough to, uh, spring, so what exactly makes them any safer than a block of the same height?
2) Judging by the number of people running these leveling kits, they are safer than blocks, so why wouldn't people run them on the REAR in place of blocks? (Besides the obvious price factor- the blocks are already there)
Old Feb 6, 2012 | 09:52 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The smaller mini packs actually replace the center pin through the pack, meaning that it's not a block only held in position by a small raised bump, it's actually part of the pack. Other brands come with a longer top leaf and Hendrick's clamps to keep the mini pack aligned with the main pack.
In the rear there isn't nearly the torsional load placed on the blocks because the axle tracks straight; on the front axle as the wheels turn the force is transmitted though the block and into the springs, and it can cause the block to pop out of position. The axle twists front to back as the truck turns; on coil spring trucks there's a radius arm/pair of link to counteract that force, but on a leaf sprung axle the pack itself takes it.
Old Feb 6, 2012 | 10:51 PM
Psyclopse's Avatar
Psyclopse
Thanks for the answer, now it makes sense. Kinda.
So on those spring packs without the longer top leaf, how would they be different from a block with a hole drilled through it to facilitate a center pin?
Disclaimer- I'm not contemplating running blocks on the front, I'm just learning the ins and outs of these mini spring packs by comparing them to blocks.
Old Feb 7, 2012 | 01:34 AM
WE3ZS's Avatar
WE3ZS
The leveling minipacks are actually a lot longer than the blocks so they are in contact with the spring over a longer span as well as being through bolted to the main spring pack. Being longer they are not as prone to act as pivot points like a block would.
Old Feb 7, 2012 | 02:12 AM
Benny76's Avatar
Benny76
That was a sweet a** answer man!
Old Feb 18, 2012 | 10:07 AM
jmimac351's Avatar
jmimac351
So, you guys are saying that this option:
Is better and safer than this option?:
The spring doing a pivot on this block did not occur to me...
Old Feb 18, 2012 | 02:44 PM
Psyclopse's Avatar
Psyclopse
No, those are two different kits for two different suspensions. The earlier Super Duty trucks are leaf sprung in the front (your first picture). Later trucks are coil sprung (your second picture, I think- if not, I've never seen round blocks for leafs).
The discussion in this thread are for the leaf sprung trucks.
Old Feb 18, 2012 | 04:47 PM
LSAtexan4x4's Avatar
LSAtexan4x4
yeah those are totally different lifts.. 99-04 superdutys were leaf spring fronts and would use the mini pack as a leveling kit.. the 05-current are coil spring front suspension and the second picture fits on top of the coil and acts as a spacer between it and the coil bucket... the only other option ive seen for leafs other than full packs is the larger shackle
Old Feb 20, 2012 | 05:12 PM
FordRig's Avatar
FordRig
man, if you wanna go all out, check out fabtech's coilover conversion system...big bucks though.
nickpohlaandp
Dec 23, 2017 06:32 PM
Metal twister
15
Jul 19, 2016 05:40 AM
jonnydz
Jul 24, 2013 08:44 AM
BobbyB
Feb 20, 2010 12:33 PM
bryan21178
Dec 29, 2005 09:12 PM
