Sponsored by: Auxito
pinion
Old Feb 6, 2012 | 09:06 PM
cjtim's Avatar
cjtim
pinion
2000 f 150 7700 series, i was going to change the pinion seal and after changing it i went to look up the tourqe specs, well on this rear end i was supposed to record the specs while breaking the nut loose , the tourqe is specified some where between 20 and 40 inch pounds, any suggestion on what i can do to keep from over or under tightening my bearing?
Old Feb 7, 2012 | 06:07 AM
Lime1GT's Avatar
Lime1GT
I usually scribe the nut and pinion before removing the nut. Then I reinstall the nut till the nuts scribe just barely crosses the pinions scribe.
It should take roughly a minimun of 160 ft/lbs torque to tighten nut before reaching the scribe.
I reread your post and see you've already removed the nut so the scribe I use won't work. sry
Old Feb 7, 2012 | 08:20 AM
cjtim's Avatar
cjtim
looks like a tear down n reset up
Old Feb 7, 2012 | 02:57 PM
Spotty's Avatar
Spotty
How much torque it takes to tighten the pinion nut, and how much rotational torque you need, are two seperate things. Since you did not take a rotational torque reading, you can probably still get close enough. You are dealing with a crush sleeve in this area. It may take 200 pds. of torque to get all the play out of the pinion, but that is not what is actually pushing on the bearings. Tighten it down until you have no play in the pinion. Then keep checking rotational torque until you get to 35-40 inch pds. You should be good.....or close....good luck...
Old Feb 7, 2012 | 08:23 PM
cjtim's Avatar
cjtim
thanks spotty, did the best i could and tightened to 25inch pnds, thanks
Old Feb 7, 2012 | 10:20 PM
steve(ill)'s Avatar
steve(ill)
cjtim, are you tightening the nut to 25 inch pounds, or measuring 25 inch pounds rolling resistance AFTER you torque to nut to 150 Ft pounds ?
Old Feb 7, 2012 | 10:34 PM
cjtim's Avatar
cjtim
Guess im not understanding the rolling inch poundd, could you explain the procedure
Old Feb 8, 2012 | 07:05 AM
Spotty's Avatar
Spotty
Hold the yoke and tighten down the pinion nut until all the play is out of the pinion...go slow as it gets close...don't back it off. It may take 150-200 pds. to do that. THEN..while not holding the yoke....wheels off the ground...,.put your inch pd. torque wrench on the pinion nut. Now...rotate the whole assembly....that is where you want the inch pound reading. Then you hold the yoke again if your reading is low and crank down the nut a snitch and recheck....
Old Feb 8, 2012 | 07:45 AM
cjtim's Avatar
cjtim
Ok thanks i definatley didnt do it right,
PM15106
1983 - 2012 Ranger & B-Series
Nov 21, 2009 09:00 PM
NORTHLAND06
2004 - 2008 F150
Sep 28, 2008 08:16 PM
zar
Feb 6, 2007 06:30 PM
gearshift101
Oct 5, 2006 09:23 PM
