LUK clutch upgrade NOT HAPPY
Okay so the 01 f350 has 106,000 miles on it and I have heard bad things about he original clutch so I decided to go with the LUK upgrade clutch. I bought it from napa and it came with the flywheel clutch disk pressure plate throw out bearing and all the hardware. After wrestling that heavy 6 speed for hours and hours we finally get it all back together. The clutch is much easier to push down and I dont hear that clunk each time i let out on the clutch like I did with the old set up (the center of the clutch disk was worn and loose) What I am not so happy about is that I can slip the clutch in all 6 gears if I get on it. I dont drive like an idiot either I most generally baby it, but I think that is ridiculous, what is it going to do when I hook up the gooseneck trailer and put my 54 f600 on it??? If I can slip the clutch at 55 with no trailer how am i going to tow with it??? I thought these clutches were supposed to be much better than the stock ones.
John_1953
05-17-2007 06:09 PM
