Confused as hell???
Old Feb 5, 2012 | 03:33 PM
rmp's Avatar
rmp
Question Confused as hell???
I have a 1997 Mazda B-2300 Series. I have no electric to the fuel pump & no electric to the fuel shut off switch under the passenger side dash. Also have no electric to the rear tail lights, blinkers, etc. Disconnected the main connection under the frame in front of the gas tank that goes to the fuel pump & the rear light section - have no electric there. Truck was running fine, changed the fuel line & now truck will not start at all - just cranks over.
Can anyone help?? Thank you in advance!
RMP
Old Feb 5, 2012 | 03:54 PM
Phinxter's Avatar
Phinxter
check fuses
Old Feb 6, 2012 | 07:29 AM
tomw's Avatar
tomw
Look under the hood near the battery. If you follow the large red wire from the + battery post, you will see where the 'rest of the truck' gets its juice. There should be one or more taps that feed the power distribution box or fusible links on the battery side of the starter relay. On the starter{other} side, there should be one large wire that goes directly to the battery. You get all power besides the starter from the battery side connection on the starter relay. I'd look for a loose connection.
tom
Old Feb 7, 2012 | 09:45 PM
79sparky's Avatar
79sparky
get a voltage tester probe at walmart for a few bucks and check it in different place for power, its very unlikely, but possible you have some broken wires.
blitzberg
Feb 24, 2014 10:13 AM
Roy Rogillio
Dec 18, 2012 12:57 PM
Rockworthy
Oct 27, 2012 04:56 PM
ladyrider_97045
1997 - 2003 F150
Jan 22, 2007 09:38 PM
78150
Aug 25, 2006 05:04 PM
