Question about ScanGauge
007E02216C1
0462451606C1
3010
000101480000
FL
But it didn't work. My truck is a 2004 is this the right information?
Second, check and see what protocol your vehicle uses, PWM or CANSF.(Mine is CANSF.) Your scan gauge can actually tell you what protocol you vehicle is. Once you figure that out enter the correct data strings and you should be cool.
CANSF:
<table id="wp-table-reloaded-id-40-no-1" class="wp-table-reloaded wp-table-reloaded-id-40"><tbody class="row-hover"><tr class="row-15 odd"><td class="column-1">
</td><td class="column-2">07E02216C1</td><td class="column-3">0462451606C1</td><td class="column-4">3010</td><td class="column-5">000101480000 FLV
</td></tr></tbody></table>
PWM:
<table id="wp-table-reloaded-id-38-no-1" class="wp-table-reloaded wp-table-reloaded-id-38"><tbody class="row-hover"><tr class="row-11 odd"><td class="column-1">
</td><td class="column-2">C410F12216C1</td><td class="column-3">0462451606C1</td><td class="column-4">3010</td><td class="column-5">000101480000</td><td class="column-6">FLV
