scangauge
Old Mar 26, 2012 | 06:47 PM
  #31
Rosson03's Avatar
Rosson03
Originally Posted by robert_l_ross
I've heard some say the cable works on two of the same device provided you are displaying different data points on both, but honestly I think at some point you will get a data collision (both devices needing a data update at the same time).
Using it with multiple devices would complicate the issue, I think.
oops wrong one.... i ment it for this one
now what if u have a ultra gauge on one side and maybe a mikes sct tuner on the other... will that clash or work together!
Old Mar 27, 2012 | 01:21 PM
  #32
Rosson03's Avatar
Rosson03
anyone think so!
Old Mar 27, 2012 | 01:36 PM
  #33
TrdLtly's Avatar
TrdLtly
TreadLightly
Originally Posted by Rosson03
anyone think so!
The first review of the adapter states: I needed to augment my dashboard with digital gauges (Scangauge II, Ultragauge,etc) and still retain a connection for a portable code reader. This cable satisfies that need quite well.
Amazon.com: Customer Reviews: OBDII Splitter Y Cable, J1962M to 2-J1962F, 1ft (145802)
Old Mar 27, 2012 | 03:26 PM
  #34
Forest's Avatar
Forest
I have a sort-of-related question about Scangauges. I have a SGII and really like every thing about it--except that I cannot also get EGT display.
So, the question is: Should I get a stand-alone EGT gauge or should I buy an Edge Insight with EGT probe and then sell the SGII? I think the Edge Insight could replace all the gauges read by the SGII(?), plus allow the EGT to be displayed.
Old Mar 27, 2012 | 03:30 PM
  #35
TrdLtly's Avatar
TrdLtly
TreadLightly
I had the Bullydog Outlook on my 7.3L. Loved it. It is only a monitor. Worked very well. You may well know that you have to have the EGT temp sensor installed to monitor EGT's no matter what gauge you use.
Old Mar 27, 2012 | 03:45 PM
  #36
Forest's Avatar
Forest
Yes. The pyrometer will definitely have to be added. And...the Edge Insight CTS is $400 plus pyrometer ($100) that plugs directly into CTS plus the mounting fixture for dash *($50). Basically, a $550 solution to make a very nice monitor of engine conditions. How about the Bullydog Outlook?
Old Mar 27, 2012 | 03:54 PM
  #37
TrdLtly's Avatar
TrdLtly
TreadLightly
The Bullydog to get now would be the Watchdog. Very similar to the Edge, but less money. Bully Dog Outlook Vehicle Monitor
Old Mar 27, 2012 | 03:58 PM
  #38
shadows4's Avatar
shadows4
That seems like a pricey solution to me. You sure you can't add a pyrometer and use the SGII? How much would a stand a lone guage run? I know I'm cheap. I have a stand alone transmission guage thats the only reason I haven't bought a SGII yet. Good luck, John
Old Mar 27, 2012 | 04:05 PM
  #39
TrdLtly's Avatar
TrdLtly
TreadLightly
Ultragauge is only $70 or so. Then add a pyrometer with probe for $150 or so. That setup would tell you anything and everything you could need to know for less then $250.
ReBilld
26
May 21, 2012 06:12 PM
Gerid
Jan 17, 2012 09:15 PM
Piolet
Dec 30, 2011 06:59 PM
427 fordman
36
Aug 13, 2010 08:16 AM
