The infamous chirp
Old Feb 14, 2012 | 09:39 PM
  #31
run6.0run's Avatar
run6.0run
Holy crap, thank you mchan for the info, I will rep you when I get home. Quick question though (i actually have lots of em), but I know I should remove the trans (manual trans) before the engine comes out, but is that the only way, I would like to take this one out without messing with dropping the trans. Would it be stupid to replace the lifters and leaving the cam? I think I know the answer though. I would like to apoligize and thank those that have helped and those that I have gotten grumpy with.
Old Feb 14, 2012 | 09:49 PM
  #32
m-chan68's Avatar
m-chan68
I have pulled my share of 6.4L and 6.0L engines on these trucks and I can tell you that the transmission can remain in the chassis, regardless if it's a manual or automatic..........
BRAINFART: You mention that you continue to hear the noise with the engine running and the belt removed, correct? Does the noise disappear when you the vehicle in gear and release the clutch? Does it the noise change or disappear whether the clutch is engaged or disengaged in neutral?
Old Feb 14, 2012 | 10:12 PM
  #33
run6.0run's Avatar
run6.0run
Me and my wife are headed south from detroit now, but I will get that info. Its kinda hard to hear with the hood down, so I will shut it down with the clutch depressed (i dont think I ever have done that), shut it down with it in gear and the clutch depressed, and if it still does it then I will have the wife put it in granny and shut it down while rolling (no seat belts under the hood tho lol). That would be awesome if it is just a clutch.
Old Feb 14, 2012 | 10:17 PM
  #34
run6.0run's Avatar
run6.0run
I can hear it while it is running, but it is way easier to hear during shutdown. Its freakin wierd tho, I have put over 4k miles on her since the noise started and it doesnt sound any different than when it started 4k miles ago.
Old Feb 17, 2012 | 10:54 AM
  #35
run6.0run's Avatar
run6.0run
Well, I got an update,,,, the freakin squeak went away!?!?!? Wtf, calm b4 the storm????
Old Feb 17, 2012 | 11:28 AM
  #36
Airzima's Avatar
Airzima
Ford replaced my alternator idler pulley and the belt twice when mine was under warranty. The chirp\squeaky noise is back again. I was told by a Former Ford diesel tech to put on a goodyear gatorback belt and my problems will be solved. We will be installing it tomorrow morning. Part # 4081261.
Old Feb 17, 2012 | 12:38 PM
  #37
run6.0run's Avatar
run6.0run
Try and start it without the belt on Arizima. That will at least let you know if you are in the right place.
Old Feb 17, 2012 | 01:01 PM
  #38
HP junkie's Avatar
HP junkie
Hopefully not, but do keep us informed. I can't believe it just went away on its own.
Old Feb 17, 2012 | 08:29 PM
  #39
Airzima's Avatar
Airzima
I believe that my issue is a belt issue not related to all of the previous posts. We will find out!
Old Feb 18, 2012 | 03:12 PM
  #40
run6.0run's Avatar
run6.0run
Will do, it definitely got my attention tho. I'm in minnesota now headed to washington state, and the father in law is on call with his trailer. Lets hope I dont have to make that call.
Old Apr 15, 2012 | 05:39 PM
  #41
run6.0run's Avatar
run6.0run
Its back..... I hope this video works.
Well what a drag. Here is a video
http://static.photobucket.com/player.swf?file=http://vid525.photobucket.com/albums/cc337/tonyyoungblood17/video-2012-04-15-17-29-38.mp4
Here is another link
<a href=http://s525.photobucket.com/albums/cc337/tonyyoungblood17/?action=view&current=video-2012-04-15-17-29-38.mp4 target=_blank><img src=http://static.photobucket.com/player.swf?file=http://vid525.photobucket.com/albums/cc337/tonyyoungblood17/video-2012-04-15-17-29-38.mp4 border=0 alt=></a>
Old Apr 15, 2012 | 06:44 PM
  #42
william_04_x's Avatar
william_04_x
No belt and it still squeaks/chirps? It almost sounded like something on the outside is rubbing on the damper. Can you tell where the noise is coming from?
Here's another link to your vid. I had trouble with the original.
Old Apr 15, 2012 | 07:03 PM
  #43
run6.0run's Avatar
run6.0run
With the stethoscope, it kinda sounded like the lpop. I'm hoping its not lifters.
Old Apr 15, 2012 | 07:06 PM
  #44
run6.0run's Avatar
run6.0run
I put the stethescope against the front cover and I could hear it. Not so much anywhere else(through the stethescope that is).
Old Apr 15, 2012 | 09:20 PM
  #45
run6.0run's Avatar
run6.0run
I checked again before putting it back together, and I can hear it with the stethescope up against the block. Doesnt matter front or back.
