ghost in the vents? :eek:
Old Feb 2, 2012 | 11:55 PM
macattack's Avatar
macattack
Question ghost in the vents? :eek:
I have noticed that when I go to accelerate all of the air out of the vents goes to the defrost ducts, but returns to where I have it set after I back off the gas.
Is this normal or is there something wrong?
Old Feb 3, 2012 | 12:55 AM
joshofalltrades's Avatar
joshofalltrades
i don't remember what year your van is, but many vehicles out there used engine vacuum to control heater functions, and would have had a check valve between the engine and the firewall where that hose went in. it would appear that check valve has failed or been bypassed, such that when you step on the gas (low vacuum), the heaters default to the defrost position until you back off far enough to have enough vacuum to bring them back. look for that check valve and replace as needed.
Old Feb 3, 2012 | 10:08 AM
macattack's Avatar
macattack
Sorry forgot it wasn't in my sig it's an 01 e 150 with the 4.6
Old Feb 3, 2012 | 11:17 AM
macattack's Avatar
macattack
Is this the right part and where is it? http://www.rockauto.com/catalog/moreinfo.php?pk=380369
Old Feb 3, 2012 | 02:51 PM
maples01's Avatar
maples01
I heard it's outside, requiring dismantling the entire heat/AC system to get at it, I've had this for over a year, we need to know where it is "really" at, inside or outside?
Old Feb 4, 2012 | 06:31 AM
JWA's Avatar
JWA
Check here too:
^^^These servos control the defrost and vent flow. Any vacuum leak here can also bring about your haunted vents.
Routing Diagram:
I don't know for certain if the check valve is underhood but it would appear to be mounted close to the vacuum reservoir. The part in your link seems to be an acceptable replacement.
HTH
Old Feb 4, 2012 | 07:04 PM
maples01's Avatar
maples01
Bigger question is, does your rear AC cut out at the same time, I know mine does, if so, it ain't in the dash, that's too easy of a repair.
Old Feb 4, 2012 | 07:13 PM
macattack's Avatar
macattack
Don't know will have to get someone to drive while i'm in the back.
Old Feb 4, 2012 | 11:18 PM
maples01's Avatar
maples01
It will go from the roof AC vents to the floor, then you'll know it's not under the dash, but the valve outside, inaccessible without total heat/AC dis assembly, as it is under the unit over the wheel well. I have heard of someone cutting the inner fender to get access to the valve, you gotta locate it to know where to cut tho.
Old Feb 5, 2012 | 06:17 AM
JWA's Avatar
JWA
Maples would it be just as easy to re-route the vacuum line from the reservoir to the Function Control Connection block to bypass and/or replace the factory mounted check valve? The new check valve could then be installed anywhere along the new hose length. This might be a lot easier than disassembling the A/C system or cutting holes in the body.
Just an idea----never done this myself.
Old Feb 5, 2012 | 09:32 PM
maples01's Avatar
maples01
I don't know where it all goes, you trace the black from the engine to find it, but I don't know how accessible the feed is to the unit inside to reroute it, then catch the rear. I'm so mad now, if I could afford it, I'd buy an electric pump, cap the factory line, then install it under the dash and be done.
I'm going to get by with this van for now, finish the modifications and upgrades to my 73, then either sell or trade this 99 for something smaller.
JTF150SC
18
Apr 11, 2018 11:15 AM
leeleeheart
Mar 10, 2011 07:08 AM
ladiabla74
1997 - 2003 F150
Jul 30, 2008 09:03 PM
Broncobudy
1978 - 1996 Big Bronco
Aug 13, 2005 05:30 PM
Snaderi
Jul 24, 2003 02:16 AM
