e350 a/c
Old Mar 9, 2011 | 03:48 PM
leeleeheart's Avatar
leeleeheart
e350 a/c
I have an 04 and an 01 that the a/c works fine untill going up hill putting a load on the engine at which point the air stops blowing out the panel and comes out the defrost instead. I couldn't find a tsb. Has anyone come across this before?
Old Mar 9, 2011 | 04:29 PM
Eric Landstrom's Avatar
Eric Landstrom
Sounds like your diverter door is flapping in the breeze.
Old Mar 10, 2011 | 07:08 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That is a classic sign of losing vacuum somewhere because the engine is providing much less vacuum under load.
If you have a vacuum reservoir, and you probably do, it has a one-way valve either in the reservoir itself, or near it. That one-way valve is probably stuck open, and allowing vacuum from the reservoir to escape back to the engine. Even if you don't have a reservoir, the one-way valve is somewhere between the engine and the heater/ac box.
Either that, or you have a leak in the vacuum system in the heater box, or broken hose between the one-way valve and the heater box, etc. etc.
Oh, and thread moved to the Full-Size Van forum.
mshargrave23
Sep 15, 2013 12:02 PM
Shovelhead 93
2004 - 2008 F150
20
Sep 16, 2012 10:17 AM
pete315
Jun 8, 2010 07:42 AM
