Quick shift cable question please...
Old Feb 2, 2012 | 09:52 PM
thewellman's Avatar
thewellman
How do you get the dang thing off? I rebuilt the column on that 97 f250 auto last week, and now it seems a good bit tight on the selector, I mean like it's taking more effort than it should on the shift lever to move from P to D and all.
I put a new shift tube / shaft / bushings / and clamps in it, greased it good, but didn't think to check the shift cable assembly for good action while it was loose.
Anyway, I thought maybe I'd pop it loose at the tranny and see how the cable drag feels by itself, that might help determine if I'm binding somewhere up in the new column parts or the cables on it's way out.
It looks like the eye on the rigid part of the cable end just snaps on to the tranny arm pin, put it wouldn't just pull off of there today like I hoped. Is there a trick? Jay
Old Jun 13, 2012 | 08:10 AM
saallencam's Avatar
saallencam
Shift Cable
Jay,
I'm assuming you figured this out by now, but I am getting ready to get into the same thing. What did you figure out AND how did the whole process go for you on the shift tube assembly? Thanks
Scott
Old Jun 13, 2012 | 03:13 PM
ReBilld's Avatar
ReBilld
The end of the cable should just pop off the shift lever. You might have to use a small pry bar to get it off. It snaps on there pretty tight.
2manytickets
Aug 27, 2017 12:35 PM
dadibones
Dec 18, 2005 07:46 PM
senseidanf
Aerostar
Oct 31, 2005 11:59 AM
johare
1983 - 2012 Ranger & B-Series
Jun 7, 2005 01:32 PM
kinglg
Jun 19, 2003 10:13 AM
