Sponsored by: Real Truck
Electronic Transfer Case ??
Old Feb 2, 2012 | 05:18 PM
1979F-150Man's Avatar
1979F-150Man
I am looking at a 99' F250 4X4 Off Road that has the switch for engaging the 4X4. What do you guys think? The truck has low miles but I am nervous about the electronic 4X4.
Old Feb 2, 2012 | 05:21 PM
1973Ford2004's Avatar
1973Ford2004
Try it and see if it works, that's all I can tell you, I have an '04 no problems so far 123,000, my problem is in my auto hub but lock still works and so does the switch.
Old Feb 2, 2012 | 06:02 PM
mwsF250's Avatar
mwsF250
The ESOF is not as complicated and potentially problematic as many electronic TC's. It is the same basic transfer case (NP241=manual, NP243-ESOF) with an electric motor replacing the lever to move and select the gears. I'd guess at least 80% of SD's got the ESOF.
It adds the switch, motor, a few more parts in the synchronizer mechanism, and vacuum actuators for the front hubs. Biggest problems arise with loss of vacuum to the hubs, but repairs are pretty simple. Many love the convenience.
The only real negatives are the loss of TC neutral, and it's more cumbersome to select 2Lo. And unless you tow your truck, or use your truck to back heavy loads, even those negatives won't bother you.
Myself, I do move heavy loads, the convinience to simply engage 2Lo on pavement is preferred over simplicity in locking hubs so I prefer the full manual TC. If I'm expecting to need 4wd, I lock hubs in advance. It takes a little throttle coordination, but the manual TC can be shifted in and out on the fly - even at high speeds. There's only been 2 times I've had to stop at an unplanned time to get out and lock hubs. I use 2Lo every time I back my trailer up a hill.
Old Feb 2, 2012 | 06:20 PM
1979F-150Man
Thanks for the replies!
Old Feb 2, 2012 | 06:54 PM
Tom's Avatar
Tom
I think there is quite a bit more of a difference between t-cases than the motor. There is a mechanism that accelerates the driveshaft and front axle to road speed before the signal is sent to lock the front hubs. This is identical in function to most other types of electronic 4WD with the exception of the hubs in some cases. In fact many use a center disconnect thats simpler in function than two lockout hubs.
Manfred Balster
Jul 27, 2019 07:51 PM
Chuck Rogers III
15
Apr 29, 2019 11:16 AM
notastroker
Dec 14, 2017 04:58 PM
ALPINE8181
Dec 23, 2010 10:20 PM
JoeyGowdy
Offroad & 4x4
Oct 8, 2009 09:28 AM
