View Poll Results: Which is better?
Voters: 34. You may not vote on this poll
Shift-on-the-FLY or Shift-on-the-FLOOR ??
The 2003 F-250 XLT 4x4 I bought has the Shift-on-the-Fly automatic button 4x4... what steps (and cost) would it take to convert it to the Shift-on-the-Floor manual shifter 4x4? Is there an online step-by-step guide with pictures for this?
You will require a different transfer case. This is not just an electric actuator that replaces a lever that sticks up through the floor.
Notice that your selector switch has no postion for neutral? The manual transfer case does.
These are small differences that make the two cases entirely different.
I know what your post is asking, but technically all transfer cases are "shift on the fly".
Grab a handfull of transfer case lever and select 4wd. As long as the front hubs are locked, the transfer case will permit engagement.
Your "ESOF" or electronic shift on the fly, system is only bad because of the potential for leaks at the front hubs. Engagement is difficult and problematic.
These problems are solved by installing manual locking hubs, and using the selector switch like normal.
It depends on what you consider "better":
If reliability is your definition then the manual is the way to go.
If convenience is your definition then the electronic is the way to go (and to stay dry)
I've done my days of jumping out in the rain/mud to lock/un-lock the hubs. Now that I'm older and (maybe) wiser, I'll stay in the cab with the wife and kids. Plus it's hard to find a used Lariat with a manual engagement system...
If convenience is your definition then the electronic is the way to go (and to stay dry)\
sorry but I don`t agree that statement. If I`m in snow then I`ll get out and lock in hubs so I know I`m in 4 wheel drive. Id just rather get wet I guess for peace of mind.
Just an avatar. A picture of a CA plate, some free text samples of "penitentiary gothic" from the internet, a little Microsoft Paint and, viola, free personalized plates!
With what CA charges me for registration EVERY year, personalized plates are out of the question...
Why does convenience and reliability have to be comnsidered anywhere near the same thing. In all of the SD's I Have ownerd over the years, including the ex wifes excursion. I have yet to ever have an ESOF system function reliably. Convenience is when something works when you need it to.
Getting wet or cold only means that the operator was not prepared for an off road journey.
When I know that I will be using 4wd, I lock the hubs before I ever get to the point of needing it. I have yet to get wet or dirty or cold when I prepare my rig before I get to the point of no return.
How many guys actually check thier 4wd system before they head out? Pretty low number, and you can take that to the bank.
Even my Sd's with either ESOF or ESOS (yes electronic shift on stop) were fairly reliable after the front hub (auto style) were upgraded to manual style.
When locked they locked, and when dis-engaged, you could count on it.
I laugh when I see many 4wd trucks, with auto locking hubs driving down the freeway with the front driveshaft turning. Stuck hubs, or a hub that did not dis-engage when the little **** was turned is a common problem that many take for granted and never check.
Part of my ritual is to check components for servicebility before, and after use, and verify that everything is working properly.
Yes, I grab each front axle stub to make sure that it is disengaged after use.
I also usually know when I will require 4wd, and for this times, the hubs get locked.
As for the "prepare" part, my bed is full of tools, food and water when I leave the pavement. I also never leave the road without a full tank of fuel. You never know what is going to happen out there, and I'm prepared for most of it. Since my wife and two kids love to off-road too, I make sure that I'm prepared to camp out in the cab for the night if need be (you can never be too prepared). And I never travel alone. I've been plenty later than anticipated, but I've never been stuck on the trail or left my rig to go back for it. That includes busting a leaf 4 miles from the pavement and 90 miles from home. It was a slow ride, but I made it home on 2x4's and zip ties holding my frame up (it was only the auxiliary spring up front, the main spring was still whole).
2 hours in the driveway now is better than $500 at the dealership later I always say!
Sure, I would prefer a mechanical system like my dad's Chevy, but when it fails, he's done. He doesn't have a manual back-up like my SD (yes, I know there is no back-up to the transfer case, but it's usually the vacuum hubs that fail).
I voted for the shift on the fly, mostly because I'm lazy. Mechanically, it's not a great system and has the potential to be a huge hassle (as my '00 has become now) but the first 5-6 years that it worked, it was flawless and engaged everytime I needed it (used to wheel alot when I lived in AZ). To get it to work now, I have to fuss with the auto/lock and half the time the hubs don't disengage so I'm stuck with engaged hubs and even crappier gas mileage than I already get. I've had them apart and cleaned/lubed but that didn't help for long. I need to dump the auto hubs, get some manuals, plug the vacuum lines and I'll be set.
In my opinion, converting over to a manual setup is not worth the effort but if you have the time and money, go for it.
hi-jacker
1999 to 2016 Super Duty
05-15-2017 10:19 AM
droldsmorland
17
07-12-2016 08:40 AM
waterski101
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-13-2009 03:55 PM
