Map sensor?
Old Feb 2, 2012 | 04:42 PM
j250hd's Avatar
j250hd
Map sensor?
My CEL is on took it to ford and they said I need a new map sensor. My question is, I've been driving it for a little bit cause it seems to run fine, mpg is still around 15, is it bad to drive like this or should I not be too worried about it?
Old Feb 2, 2012 | 04:59 PM
fordpride's Avatar
fordpride
It's not gonna hurt it
fordpride's Avatar
fordpride
Dud they give you the code?
Old Feb 2, 2012 | 05:28 PM
j250hd's Avatar
j250hd
No code. Forgot to ask. Had it at another diesel shop and they couldn't even get their scanner to sync up.
Old Feb 2, 2012 | 05:50 PM
427 fordman's Avatar
427 fordman
Unplug the electrical connection to the map and drive it and see if it runs better. That usually tells you if you have a bad sensor. It will cel, but if it runs better, the map is bad.
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
ballbandit
Escape & Escape Hybrid
Jul 11, 2009 10:32 PM
dmanier
1978 - 1996 Big Bronco
Oct 27, 2002 04:46 PM
