Oil filter?
Old Feb 2, 2012 | 11:00 AM
Crewcab Turbo's Avatar
Crewcab Turbo
Oil filter?
Is there a better/larger oil filter other than motorcraft available at napa? Thank you
Old Feb 2, 2012 | 03:56 PM
SARDiverDan's Avatar
SARDiverDan
I guess the first question would by why you may need a larger oil filter. The FL1995 from motorcraft is about as large as they come for regular use. Once in a while I use a K&N filter but they are basically the same filter. If you are looking for better filtration you might go with AMSOIL - By-pass Oil Filter Mounting Kits I bought this unit and I still need to find some time to get it installed. Are you limited to just what is available at your local NAPA store? They don’t even sell motorcraft at the NAPA near my house; they just have napa, nascar, and K&N
Old Feb 2, 2012 | 04:06 PM
ToMang07's Avatar
ToMang07
I'm running the BHOF!
https://www.ford-trucks.com/forums/1...il-filter.html
Old Feb 2, 2012 | 09:02 PM
timmyboy76's Avatar
timmyboy76
Thats one expensive filter....Napa / Fleetfilter has them...51792xd is the p/n
http://www.fleetfilter.com/mm5/merchant.mvc?
Old Feb 2, 2012 | 09:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check out the BHOF. On paper it has better filtration and capacity than the Motorcraft filter, however I have never used it myself.
http://outlawpsd.com/forum/7-3-membe...e-oil-filter)/
Old Feb 2, 2012 | 10:24 PM
ToMang07's Avatar
ToMang07
http://outlawpsd.com/forum/7-3-member-write-ups/bhof-big-honkin-oil-filter-(donaldson-elf7405-endurance-oil-filter)/
I am currently 5k into my BHOF... I will be sending out a UOA at 10K and report back... but I expect the results to be better than the OEM filter, based on the filter's specs.
A/Ox4's Avatar
A/Ox4
9 ECHO 1
For good reason
Next oil change I might a BHOF
Old Feb 3, 2012 | 11:35 AM
Crewcab Turbo
Thanks for the replies I think I will try the BHOF. Thanks
Old Feb 3, 2012 | 12:47 PM
timmyboy76's Avatar
timmyboy76
For the price of that filter and along with 20 buks, you can create/install a by-pass oil filtration system, and extend your oil change intervals, greatly...just say'n
Old Feb 3, 2012 | 05:32 PM
Crewcab Turbo
Good idea. Where do I get one for that price?
Old Feb 3, 2012 | 05:52 PM
timmyboy76's Avatar
timmyboy76
piece it together. Springerpop and WoodNThings, has a great write-up on what used and where to find. I, went thru Fleetfilter.com, got my filter and filter base for 30 buks. The fittings i add extra from my wvo set-up, and same as the tubing used, which is bio-fuel line, rated at 120psi, which i found is nothing more than the r9 fuel line from Autozone. You can get Napa to rig you up a set of fittings/hoses, but now your talking around 100 buks for that giddyup, and then the base/filter...you can check out my album oil-bypass.
SpringerPop's Lube Bypass Filter
Wood-N-Things set up https://4656923915310766587-a-180274...attredirects=0
Old Feb 3, 2012 | 06:26 PM
SpringerPop's Avatar
SpringerPop
I suspect the best full-flow oil filter you can buy for our Powerstrokes is a Fleetguard LF9027.
Pop
Old Feb 3, 2012 | 07:51 PM
ToMang07's Avatar
ToMang07
Pop
Any specs on that filter?
Only thing I can find about it is it's made in India.
Old Feb 3, 2012 | 09:29 PM
SARDiverDan
This may help a little
File Type: pdf
Old Feb 3, 2012 | 09:37 PM
ToMang07's Avatar
ToMang07
That's a great little sales brochure.... But I'd still like to see specific specs.
elishaman
Aug 11, 2019 12:15 PM
bfife
Jul 27, 2011 07:03 PM
landis76
May 3, 2010 10:38 PM
2fords2
Oil & Lubrication
Aug 26, 2002 09:10 AM
