PCV vacuum leak
Old Feb 2, 2012 | 08:30 AM
jaredm_k's Avatar
jaredm_k
PCV vacuum leak
I was checking for vacuum leaks last night and I found one on the back of the carb where the PCV line runs to. Right now there is no fitting or anything back there - just a 3/8" metal line with rubber insulation to seal it off. Is there any way to make it more secure/completely seal it off?
The rest of my vacuum lines are good so I think this is my only leak (for now).
Any help would be appreciated.
Old Feb 2, 2012 | 09:46 AM
Stinky7-11's Avatar
Stinky7-11
Is your PCV system not connected? Make sure it is working, it should be connected to the fitting your describing, photos?
Old Feb 2, 2012 | 11:25 AM
jaredm_k's Avatar
jaredm_k
Thanks for your reply. It is working and was hooked up. I was spraying carb cleaner (looking for leaks) and it is clear there is one in this location. Is there supposed to be a fitting screwed into the carb that a vacuum hose would go on to create an air tight seal. Right now it is just a metal line that sits in the vacuum port on the carb. I will try to snap some pictures tonight.
Old Feb 2, 2012 | 11:58 AM
Stinky7-11's Avatar
Stinky7-11
Funny i think mine may be loose also , i will take a look a let you know LOL
Old Feb 2, 2012 | 12:03 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Metal end with a rubber sleeve over it? Usually this is a "press fit" nipple that can come loose from the carb. Under that rubber sleeve, is a joint in the metal line. The nipple is supposed to stay in the carb, while the rest of the metal line can separate at the rubber sleeve.
Pull the nipple out of the rubber sleeve, and carefully tap it back into the carb. Adding a little sealer isn't a bad idea. Then replace the rubber sleeve (most likely hard as a rock by now) and reassemble.
Old Feb 2, 2012 | 01:07 PM
jaredm_k's Avatar
jaredm_k
Thanks Rogue_Wulff, that makes sense now. Is there any particular sealer you would recommend for that press fit into the carb? I'll definitely replace the rubber too as it is starting to rot. Thanks again guys!
Old Feb 2, 2012 | 03:50 PM
Stinky7-11's Avatar
Stinky7-11
Funny, I said i was going to look at mine and sure enough it was loose too. I used a little permatex and gave it a few taps , i save leftover hose and that was it, found a 2" scrap! I see RW got you set, Perfect!!
Old Feb 2, 2012 | 03:59 PM
jaredm_k's Avatar
jaredm_k
Thanks Stinky, I'll take care of it this evening!
Old Feb 2, 2012 | 04:07 PM
Rogue_Wulff
Yep, permatex works quite well for this.
I, too, always save the little leftover pieces of fuel hose. Never know when 1 might come in handy.....
Michael Waid
Jun 28, 2018 06:43 AM
Gonu50
Sep 16, 2012 08:00 PM
ldst
Aug 4, 2012 04:31 PM
dsmisfits
Nov 20, 2010 09:21 AM
Pat D.
Jan 12, 2010 09:43 PM
