FRx - Results?
Old Feb 2, 2012 | 12:55 PM
woodnthings's Avatar
woodnthings
I really think it is a great upgrade and a quality kit. The idea that the fuel isn't "dead-headed" in the fuel rail also helps. I think you will see a noticeable change in how the truck idles too!
Old Feb 2, 2012 | 01:14 PM
Rose Clifford's Avatar
Rose Clifford
Hutch mod made a huge difference for me
Old Feb 2, 2012 | 01:59 PM
PEI's Avatar
PEI
Never did the hutch/harpoon mod yet.. guess thats on my list to do.. Did you all install another in line filter or not bother?
Thanks!
Old Feb 2, 2012 | 02:56 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by woodnthings
Trey,
I put it on my truck and noticed it quieted down the sound and it seemed to run smoother. I ended up checking it with AE and the data clearly shows the FRx improved the PERDELS on mine.
Here is a post from the thread I started after installing the next gen FRx. Read the whole thread for more information.
https://www.ford-trucks.com/forums/1...ml#post9687039
I observed improved PERDEL numbers as well. However, in my case I installed the FRx and black CPS at the same time. Seems like they compliment each other because both of our pickups idle quite nicely.
Originally Posted by Riffraff Performance
Now you have an option that it can come with a cover as well
That covering is pretty nice.
Since Trey is going for the stealth look, he might have to do something about the Riffraff brand on the FPR housing as well.
Originally Posted by SteveH-CO
Not be a wet blanket, but I did the hutch mod, and based on my testing, very little air is still in the fuel at the fuel bowl. This mod greatly quieted my engine. I'm wondering how much more smoothness/quietness I would get from the FRx mod. Would it just be another 10-20%, or a quantum leap (as the hutch mod was)?
I realize that the FRx also provides better fuel pressure feedback info, so it's not only about the air in the lines.
I think you will still see some additional improvement. The Hutch Mod gets you back to a good running stock system as far as air contamination goes. Air in the fuel line isn't a problem until the pickup assembly breaks/cracks or the screens begin to get clogged. When the screens are clogged, the OEM fitting ahead of the fuel pump can allow air into the system due to a pressure drop at that point. At that point the engine starts to get a lot more noisy and performing hutch mod will make a big difference. In your case, the FRx will be a subtle change, but still worth the effort IMO...
Old Feb 2, 2012 | 03:15 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
You're right, it's not only about the air. Since #6 fires right before #8, and the fact they sit side-by-side, #8 doesn't always get it's fair share of fuel sitting at the end of the deadhead fuel rail. Open up that deadhead fuel rail with an FRx and #8 will be much happier with a better volume of fuel and might even last a bit longer because it will be better lubed. The fuel section of the injector is only lubed by the fuel, and any additves you may add to the fuel.
Old Feb 2, 2012 | 03:38 PM
timmyboy76's Avatar
timmyboy76
Thanks!
Ya, you should have some type of pre-pump filtration. If its only a clear bubble filter, its atleast something.
Old Feb 2, 2012 | 04:24 PM
PEI's Avatar
PEI
Thanks
Jason
Old Feb 3, 2012 | 11:39 AM
SteveH-CO's Avatar
SteveH-CO
I installed a screw-on 10 micron filter just ahead of the tank - after I did the hutch mod. I like the fact that my fuel pump now only sees cleaner fuel, too. Ripping all that badly-engineered junk out of the fuel tank and replacing it with stainless lines brought joy to my heart.
Old Feb 3, 2012 | 12:47 PM
cj45lc's Avatar
cj45lc
I kinda went about it *** backwards, I put the FRX on before doing the hutch mod just to see what difference I would notice if any. Made quite a bit of difference quieting the engine by itself, so much so that if my brakeline that runs behind the fuel tank hadn't rusted out I probably still wouldn't have done the hutch mod. JMHO but I really think this is 2nd best thing I've done to my truck only behind putting Bill's tunes on it
Old Feb 3, 2012 | 02:00 PM
Rose Clifford
Thanks!
I installed an in-line baldwin spin on filter
woodnthings
20
Oct 29, 2012 12:44 PM
Tugly
25
Apr 7, 2012 11:33 PM
ToMang07
Aug 31, 2011 03:12 PM
ToMang07
13
Jun 6, 2011 06:16 PM
