Wrench day on its way!
April 28th at woodnthings hangout is coming soon and I want to get some stuff done. I figured this would be a good topic to share, so here it is:
Here's the question: Without busting my wallet open like a piñata (I do enough of that without help), are there any suggestions for maintenance while I have "Stinky's" guts splayed about? Please bear in mind I have a pretty full dance card already and this needs to be done in one day.
- All sensors reading normal
- Mods in sig
- Tired HPOP
- Occasional injector knock in the parking lot when in gear (just one)
- Last fuel filter had black (algae?) on it - changed
Smokie
I replaced the HPOP lines on mine when I swapped over to the T-500. I figure it is a great insurance policy that will keep me from being stuck miles away from a replacement line on a Saturday at 4:00 (seems to be when they let go). I keep the old ones in the truck as spares.
In reality, you only have about 4 hours worth of work there. You could always buy a few more parts to fill up the day of wrenching!
Oh.... I threw a complete O-ring kit on the list for good measure. I know how these things go - every part can earn the nickname "Touch-N-Spew".
I'll be there as well. Probably going to try to tackle studs/springs/pushrods and if time allows a melling LPOP. Planning on being there bright and early at 8am as I will need to be out of there around 8pm. I feel confident that I will be able to get it done, but will definitely need some help/advice as I have never tackled these things before. Especially nervous about the spring install. Headstuds seem to be a simple matter of unbolt the stock bolt, insert stud, torque to spec...just time consuming because there are so many...is this right?
on edit, Tugly, where in eastern WA are you? me and spool&go will be heading over from ellensburg. If youre anywhere near we should all caravan over
One nice thing about 2 is I get to use the Snake Brake westbound.
OK. It's been a full day so far and HPOP lines are on my list (thanks to bfife and woodnthings) and I added an O-ring set. While I was waiting for input, I replaced my power steering pump - it's a lot smoother now. I take it I have enough "gotchas" covered on my list?
Chet
