Hi everyone. I recently replaced objectors #4 and about a month later I get a code #4 cotrobution/balance. I have this code on cylinders 5,7 and 8 as well. #8 and #4 don't always come up but #5 & #7 are consistent even after I clear the codes. The truck runs great cold but when it warms up it runs like complete ****. Can I get some ideas and ways to figure our whats wrong. My code reader only reads codes can't us it to do any testing.
FMP runs from 44.5 to 47 volts on cold start at 74 degrees for 5 minuets or more then slowly climbs and runs from 45 to 48.5 volts. FLP & FVP run 13 to
13.5 volts. I get 13.8 to 14.0 out of alternaters. The FICM is grounded.
Even if its just a couple of minutes? That sucks. Thanks for the help. maybe now I can finally get my truck to run right. But..... Now I have a trans problem. Uhhh. Too much power for the stock trans.
