Lopeing after chip install
Old Jan 31, 2012 | 08:18 PM
444dieselrod's Avatar
444dieselrod
It's been awhile, refresh my memory why my truck is doing this....
I drove the crew cab Sunday to get a feel for it got home and put the chip in.The truck has an ALF4 pcm, The chip is burned for a TDE1. The ALF4 is a manual pcm, the TDE1 is an auto. Last I knew you could run an auto pcm/chip in a manual truck no problems but now as soon as it starts it lopes real bad till you rev it. Does it hot or cold.
Should I just put the TDE1 pcm/chip combo in or just get the chip reburned? What's the "best" manual trans pcm code.
DiesleRod
Old Jan 31, 2012 | 08:26 PM
redman84's Avatar
redman84
Is it something like this?
Kris and his loping 7.3 - YouTube
Old Jan 31, 2012 | 08:35 PM
444dieselrod
That would be it.
Old Jan 31, 2012 | 08:38 PM
fordpride's Avatar
fordpride
With the auto chip it's looking for the TRS tran range sensor
Old Jan 31, 2012 | 08:59 PM
JamesHajek's Avatar
JamesHajek
Just get the chip reburned for your pcm code...
Old Feb 1, 2012 | 08:01 PM
444dieselrod
Thats what I figured I would have to do. so whats the lates and greates manual trans code, and does anyone have a list of PCM codes around? I recall seeing such a list 3 years and 3 computers ago so the odds of me having in bookmarked somewhere are long gone.
Diesel Rod
Old Feb 1, 2012 | 08:11 PM
KonaGrown's Avatar
KonaGrown
Ever since I got my chip from Tony, it will lope like that when I switch from a higher hp tune to a lower hp tune. Other then that, the truck runs like a champ. Anyone else have a problem like this? Maybe I just have to clean the contacts a little more...
Old Feb 1, 2012 | 08:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Diesel Rod
Maybe this helps you
PCM CODES.
94 manual - BEG6 BEG 8
95 manual - SOD4 SOD5
95 auto - PRY4 TEE4 TEE5
96 manual - ALF4 AUG4 AUG6 AUG7
96 auto - MIF4 MIF6 MIF7 NAW4 NAW6 PRE4
97 manual - ALF6 JKA2 JKA3 MLE0 MLE1
97 auto - MME2 MME3 MME4 MME5 MME6 NAW6 TDE0 TDE1 YBT0
Powertrain Control Module (PCM) Codes PCM Codes - 1994-1997 Power Stroke FAQ
Old Feb 1, 2012 | 11:08 PM
PstrokeN's Avatar
PstrokeN
with my programmer mine lopes sometimes to
Old Feb 2, 2012 | 07:02 PM
444dieselrod
PCM CODES.
Thanks, I found that same link late last nite.
Is it safe to assume the MLE1 is the one to get? I have ran NAW4, TDE0 and TDE1 and the TDE1 is by far superior to the others.
Diesel Rod
Old Nov 14, 2017 | 10:21 PM
Joe White254's Avatar
Joe White254
PCM CODES.
should the mle1 code chip work on a sod4 pcm?
snakedoc
Ford Truck Parts for Sale
Sep 30, 2012 12:13 PM
f1501987
Dec 3, 2011 02:55 PM
papadelogan
13
Dec 10, 2009 08:41 AM
hedhntr
17
Aug 15, 2007 07:01 PM
tbax46
Computer Chips & Tuners
Aug 9, 2005 10:50 AM
