i need some help with my brakes
alright, i have a 99 ford ranger with a 4.0 and auto trans. my brakes was starting to feel real bad a while back so i replaced both front calipers, pads, rotors, bearings, brake booster and master cyl. i replaced the booster because i could hear it leaking vacuum in the truck when i would press the pedel. well went through a gallon of fluid when bleeding them out and using a catch bottle so it would not suck air back in. i could not get any pedel. so then i thought about the the pushrod on the booster. i sdjusted the rod until i got a good feeling pedel. well the truck will stop but sometimes it requires more effort than other times. sometimes i have to go to at least half travel of the pedel before i can feel the brakes starting to grab. i dont think i have abs. i do have a abs light on dash but i only have a porportioning valve under master cyl. the only sensor i see around any of the wheels is the one in the top of the rear end which i replaced because my speedo quit working.
i have run out of idea with this. i can get it to stop but sometimes it takes alot more effort. i dont hear and vacuum around the booster, i dont see any leaks on amy of the lines or at any of ther wheels.
thanks for the help.
i listened for a leak but cant hear one. i also held a lit cigg all around the booster wanting to see the smoke going into it somewhere and also did not see a leak. my old booster i could hear the swoosh from inside when i pressed the brake pedeal. with this new one i dont hear nothing.
sandymane
49
10-20-2018 07:37 PM
6erwebb
08-06-2015 11:09 AM
alcan60283
04-09-2007 03:46 PM
