Sponsored by: Kumho
Brake problems
Old Mar 6, 2012 | 10:04 PM
Shanemh's Avatar
Shanemh
Brake problems
Just had a friend, who is mechanically minded do a front brake job on my truck. Pads, rotors, calipers, bearings, master cylinder etc. Put everything on, bled all the brakes, calipers and when we push on brake pedal, it goes all the way down to the floor like theres no pressure. clamped the front and rear lines to see if the master cylinder was failing. Brake pedal went half way down and held pressure. Not quite sure what to check next? Any ideas??
Old Mar 7, 2012 | 04:57 AM
Lazy K's Avatar
Lazy K
Would seem like there is still air in the system. Did you bench bleed the new master cyl before fitting it?
Did you bleed brakes in correct sequence? Correct order is right rear, left rear, RABS module, right front, left front.
Old Mar 7, 2012 | 07:11 AM
JWA's Avatar
JWA
Bench bleeding the master cylinder is vital when its replaced. Like Lazy K says there's still air in your system---its time to back up and bleed everything again, this time properly.
Old Mar 7, 2012 | 09:58 AM
Shanemh's Avatar
Shanemh
Ok. Thanks for tip. I'll go back and start the bleeding process again.
Old Mar 7, 2012 | 10:45 AM
Lazy K's Avatar
Lazy K
Make sure you bleed the RABS module, a lot of people forget about it and then can`t get brakes. Make sure also that the rear brake shoes are fully adjusted up.
Old Mar 7, 2012 | 07:20 PM
Shanemh's Avatar
Shanemh
Where is the rabs module and what does it look like?
Old Mar 8, 2012 | 07:14 AM
Lazy K's Avatar
Lazy K
It is bolted to the inside of the drivers side frame rail about level with the drivers feet. Follow the brake pipe from the master cly down the firewall and you will come to it. There is a bleed screw on it and it is bled just like a brake.
Old Mar 9, 2012 | 05:34 AM
stuart1's Avatar
stuart1
If you changed the master cylinder the booster rod may need adjusting.
Remove the master and turn the adjuster out to contact the piston in the M/C.
Don't go too far or brakes will be applied all the time.
Amish65F100
38
May 25, 2017 11:10 AM
JU71
Feb 20, 2012 11:37 AM
Danny D
Nov 6, 2009 09:35 PM
951500
Nov 5, 2008 07:09 AM
fordbidden dreams
Bronco II
Nov 7, 2003 09:21 PM
