Trouble Shooting Help
Old Jan 31, 2012 | 10:26 AM
MinGry03's Avatar
MinGry03
Hello all. I need a bit of help with trouble shooting our fire company’s 1988 E350 7.3 diesel ambulance. We picked it up from paint on Friday and as we were approaching a red light, the vehicle just shut off. No puttering, backfire or anything. Upon trying to restart I noticed the "wait to start" and the other warning light that usually comes on, doesn’t. The engine will turn over but not start up. When we picked the vehicle up in TN, we had the lift pump, one of the injectors fixed and the starter replaced before bringing it back to Pittsburgh. Logic tells me that is seems to be an electronic problem but I don’t know where to start looking on a diesel. Any help trouble shooting this problem would be greatly appreciated.
Old Jan 31, 2012 | 10:52 AM
Lazy K's Avatar
Lazy K
You may have lost power to the fuel shutoff solenoid (FSS). If you look on the injector pump (between the V at front of engine) the Wire connection to the FSS is the one nearest to the front of the engine. With key "on" you should have 12v at the wire and also when you unplug it and pulg back on you should hear the solenoid click. Check that out.
You can also jump from a positive battery terminal to the FSS and see if the engine then starts.
Old Jan 31, 2012 | 10:56 AM
Phy's Avatar
Phy
With the wait tor start light off, I'd be looking at power to the fuel shut-off solenoid. With the key on, there should be 12v to it. It's the connector toward the front, on the drivers side of the IP...
btw- You're having trouble shooting your help?
(Sorry, couldn't resist... :-)
Old Jan 31, 2012 | 10:57 AM
Phy's Avatar
Phy
Ahh, you beat me to it LK
Old Jan 31, 2012 | 10:58 AM
MinGry03's Avatar
MinGry03
This might sound stupid, but what does the injector pump look like? Also is it on top of the engine?
Old Jan 31, 2012 | 11:08 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
the injection pump is at the top, center, front of the engine.
Old Jan 31, 2012 | 11:20 AM
Phy's Avatar
Phy
That pic is looking at it from the passenger side. The throttle cable connects to it on the pass side, and there are two electrical connectors on the drivers' side. The front one of those two is the one you want...
Old Jan 31, 2012 | 11:43 AM
MinGry03's Avatar
MinGry03
Thanks, for the info. I will look tonight.
Old Feb 1, 2012 | 09:38 AM
MinGry03's Avatar
MinGry03
I did not get a chance to look last night but I do have a few questions.
1. What if there is no power to the solenoid? Is there a fuse that could have blown or a relay go bad?
2. What is there is power? What would be my next steps?
Old Feb 1, 2012 | 10:35 AM
Phy's Avatar
Phy
You really need the wiring diagrams for your truck. I only have the wiring for the later ones, but it's likely the same...
The reason I suspect an electrical issue is that the wait to start light isn't coming on as well. On the later trucks, when the key is turned to on or start, the ignition switch supplies power to fuse K in the power distribution box, then from fuse K, to the glow plug controller, to the fuel shut-off solenoid, and the temp switch, cold idle solenoid, and cold timing advance solenoid. If that circuit is bad, it would do exactly what you're describing...
Old Feb 2, 2012 | 08:44 AM
MinGry03's Avatar
MinGry03
Well after checking the wire for the fuel shut off solenoid, I did not have power to the wire. So we traced the wires and found out that the wire harness from the alternator was melted into a nice mess. BINGO, there is my problem. Now I have to figure out the who, what, when, were & why this happened. I’ll keep you all posted.
Old Feb 2, 2012 | 01:16 PM
bashby's Avatar
bashby
A lot of ambulances have larger or even dual alternators installed, just something to keep in mind if it doesnt match up to wiring diagrams and other trucks/vans of the same vintage.
Old Feb 25, 2012 | 01:05 AM
MinGry03's Avatar
MinGry03
Well we got our vehicle back from the repair shop last night. The problem was a few wires that got over heated and melted. So as we inspect the repairs, we notice a small amount of smoke coming from what looks to be this solenoid when the key is on and not running. I don’t know if it might have some left over diesel fuel on or in it from a bad injector that was leaking but the yellow wires get nice and hot. I don’t want to put this in service and have it catch fire. If anybody could help me out with what is this part, what does it do and should the yellow wires get hot would be greatly appreciated.
Old Feb 25, 2012 | 06:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
that is the glow plug relay.
those yellow wires carry a lot of current to heat up the glow plugs, but they will only be hot for a few seconds. once the engine is running the power is shut off and the wires should cool off.
hollywoodswole
Feb 29, 2012 02:19 PM
f250d4x4
Oct 27, 2011 11:11 AM
LARRY5469
Sep 1, 2009 04:12 AM
West
Jul 2, 2007 03:57 PM
jrwhitey_2000
Nov 15, 2005 01:53 PM
