F10= F series 1/2 ton 2WD truck
Y= 352, 2bbl V8 engine
K= Kansas City Assy Plant
817XXX= Feb 1966 Build date, 1966 model year truck
115= wheelbase in inches
A= exterior color...Black
F100= 1/2 ton truck, 5000# GVW
E= Red Crush Vinyl & Red Cody Pattern Woven Plastic(Custom Cab pickup)
81= conventional cab truck, 81B is bore out in interior trim explanation in
Master Parts Catalog which is a Custom Cab trimmed truck in this case.
C= 3 speed light duty manual transmission
08= 3:50 ratio rear differential, open assembly(non locking)
5000= trucks max GVW with full load of fuel, persons and cargo in pounds
172@ 4000= Engines certified NET HP at the specified RPM
25= DSO= Richmond, Va...where the original selling dealer ordered the
truck from. This was not a special order truck, it was bought off the lot.
