coolant engine code
Old Jan 30, 2012 | 01:50 PM
gogreenwave's Avatar
gogreenwave
coolant engine code
Hello,
My check engine light came on recently in my 4.0L 08 ranger. When I took it to Kragen to have them see what the code was it said it was taking too long to warm up to operating temp. I have noticed that is is running slightly cooler than normal, even once it is driven for a long time. I am thinking the thermostat is stuck open. My problem is I want to be sure that it is the thermostat and not a faulty sensor telling the thermo to stay open. I am not sure if the sensors in the cooling system even work that way.
I have an extented warranty, but it has a deductible so if it is the thermostat it would be much cheaper for me to just fix it myself. If it is a sensor, then I would rather take it in and pay the deducible. Can I be sure that it is the thermostat?
Thanks for the help,
Matt
Old Jan 30, 2012 | 04:48 PM
03 Maz B23's Avatar
03 Maz B23
Depending on the mileage on truck the emission control warranty may cover it without deductible if it happens to be a sensor triggering the light. Check your emission warranty booklet to verify. Check your extended warranty for all the exclusions (there tend to be a lot) as am not sure the thermostat would be covered. As for the stat are you noticed a dramatic difference in the heat from the heater? If so that would more likely indicate the stat.
Old Jan 31, 2012 | 10:02 PM
aquanaut20's Avatar
aquanaut20
The stat is a mechanical device that reacts to engine coolant temp... it is no way connected to any sensor... for the $5.00, change it ... Philip
bhlass
Escape & Escape Hybrid
Feb 6, 2018 05:49 PM
tbar1963
6.2L V8
Apr 1, 2017 10:49 AM
Super crew hunter
1997 - 2003 F150
Apr 11, 2013 06:41 AM
Heavenword1
Dec 5, 2007 05:23 PM
John_E
Feb 18, 2004 07:53 AM
