Noob with starting issues
Old Jan 30, 2012 | 01:47 PM
Free55's Avatar
Free55
Hello everyone, I'm usually over in the F100 side. I have a '60 F100 and a '55 F100 project.
Well I'm helping a farmer friend on his F450 7.3L. It starting running rougher and hard starting. Someone else already changed the injectors and I don't know which ones were used.
Here's the symptoms:
With the key on the on position the IDM relay in the fuse box is clicking which leads me to believe the is short some where.
If I ground the red wire on the GP relay the clicking stops and it will start.
Same thing if I send 12v to the other side of the relay. The smaller post, brown wire I think.
With the key on it should energize the entire GP relay with 12v. I'm only getting 12v at the power feed. The two small post are only getting roughly 7.5v and the injector side brown and yellow 0.0v.
Yes I've changed the GP relay and it's still doing the same thing.
One last question, where the heck is the IDM? All I can find is what I think is the EEC. Driver side kick panel. Oh and It's a CA model.
Any suggestion will be greatly appreciated.
Old Jan 30, 2012 | 01:53 PM
nlemerise's Avatar
nlemerise
The IDM is under the drivers side front fender near the firewall. Remove the wheel liner to get to it. Heck, if it starts when you jump the GPR, then my attention is on the GP-system first. Maybe put a momentary switch to energize the GPR when needed (cold starts).
Old Jan 30, 2012 | 01:59 PM
Free55's Avatar
Free55
Thanks for the quick reply. I've thought about that. I forgot to mention when it's running I'll getting the same voltage as when the engine is turned off and the key on the "ON" position. Weird.
Old Jan 30, 2012 | 02:11 PM
BigAlsPSD's Avatar
BigAlsPSD
The GP relay is provided a ground by the PCM, so it will have voltage both sides of the coil. without a ground.
Here is a pick of the location of the IDM, with the fender removed, which is not needed to access, just the wheel well.
Name:  IDM without fender.jpg
Old Jan 30, 2012 | 02:19 PM
Free55's Avatar
Free55
Cool I have the IDM schematic and testing procedures.
roots4thought
May 19, 2016 01:59 PM
tylerc82588
Jun 26, 2013 12:36 PM
dothedew192
Mar 11, 2012 08:32 PM
62trvler
17
Dec 22, 2006 09:32 AM
diggum
1978 - 1996 Big Bronco
Jan 14, 2003 10:30 PM
