Another another no start
Old Jan 30, 2012 | 12:14 PM
ygbsm's Avatar
ygbsm
I know there's many of these posts, can't seem to match my issue. 75mph, ses light came on, engine died. Towed home. rpl'd cps, chkd fuses, chkd hpop oil level, disconnected icp(no oil in connector)chkd pcm connector. wts light works, no tach movement, no obd faults, no smoke. turns over fine, batteries new. 2000 f350 7.3 automatic. Any help would be appreciated. Thank you.
Old Jan 30, 2012 | 01:01 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jan 30, 2012 | 01:05 PM
ygbsm's Avatar
ygbsm
Sorry. I must have put this in the wrong place. very green.
Old Jan 30, 2012 | 01:12 PM
powerstroke72
No problem at all.
I just moved you down here where you'll get better assistance from the 7.3 folks.
Old Jan 30, 2012 | 01:17 PM
nlemerise's Avatar
nlemerise
Have you tried checking fuel flow? No smoke indicates no fuel to me...Open the fuel bowl drain and get turn the engine over. You should get a lot of diesel spewing out. If not, make sure the fuel pump runs when you turn the key on the KOEO position. It should run for 20 seconds or so, then shut-off. If it does run, then maybe the pickup screens in the tank are plugged.
Old Jan 30, 2012 | 01:33 PM
ygbsm's Avatar
ygbsm
Thanks, Neal. Will check the drain port. Pump does run when key turned on. Lack of tach movement seems to point back to cps, according to previous posts I've read.
Old Jan 30, 2012 | 01:35 PM
PaysonPSD's Avatar
PaysonPSD
You probably did a lot of cranking trying to get it started when it first died. Now make sure you have 10.5 volts WHILE cranking to start.
No smoke is also a sign IDM is not firing the injector solenoids and it needs 10.5 volts to do so.
Old Jan 30, 2012 | 01:38 PM
ygbsm's Avatar
ygbsm
Will check voltage. Have kept it on a charger once it was home, as many posts mention the voltage requirement. Thank you.
Old Jan 30, 2012 | 01:43 PM
PaysonPSD's Avatar
PaysonPSD
Did you use an OEM or parts store CPS?
Old Jan 30, 2012 | 01:55 PM
ygbsm's Avatar
ygbsm
Cps was from Ford dealer. It's grey. Have seen posts where they are bad from stock. Is there a way to check them?
Old Jan 30, 2012 | 03:11 PM
PaysonPSD's Avatar
PaysonPSD
Not really. Just make sure it is installed correctly and the connector is seated properly.
I far as I know this is the latest CPS.
Old Jan 30, 2012 | 03:27 PM
ygbsm's Avatar
ygbsm
That is NOT the sensor I got from the parts guy. it was grey with pt #f7tz-12k073-b. It matched the one I took out. Could that be an issue?
Old Jan 30, 2012 | 03:43 PM
PaysonPSD's Avatar
PaysonPSD
NO, not if it is a good CPS. It should still start. The grey one(pt #f7tz-12k073-b) is just an earlier replacement. That is the same part number they used as a replacement during the CPS recall in late 2007. They caused some phantom DTC codes and CCT failures on #8. The new DU-87 seems to have solved those problems. I really believe they should have sold you the DU-87. The parts guy probably doesn't even know the difference.
Old Jan 31, 2012 | 08:27 PM
ygbsm's Avatar
ygbsm
Just a quick update. First, thanks to everyone for their help. Still not fixed. Read another thread that said without a tach signal, it won't start. Focused on that. swapped out relays 30 and 32. replaced cps sensor with black one. checked connections, no help. Was going to chk wiring from cps to 42 pin connector, but couldnt read any pin numbers on connector to get a starting point. Stock motor, no chip. Wouldn't be so bad, but I've only put 5 miles on this truck!
Old Jan 31, 2012 | 08:40 PM
F350-6's Avatar
F350-6
How did it die? Spit and sputter or like someone shut the key off? You said no OBD faults. What did you use to try to pull the codes (96 and newer OBDII code readers won't pull engine codes on this motor). No smoke out the tailpipe at all while cranking? I don't suppose you have access to a scanner capable of monitoring live data?
