TPMS breakdown for dummies
Old Feb 1, 2012 | 02:38 PM
doczenith1's Avatar
doczenith1
It is my understanding that the threshold is set at 75% of the recommended 65psi front and 80psi rear pressures. I like to run my rears lower than my fronts when unloaded so I retrained the system and told it that the fronts were in the rear and the rears in the front. I aired down to 80% of recommended and after a few days the light came on so I went to 85% which puts me at 68psi for the front tires and 55psi for the rears and have not had the light come.
Per Michelin and my actual axle weights I can go even lower without safety issues.
Old Feb 1, 2012 | 10:26 PM
todster's Avatar
todster
Originally Posted by SneakyF350
If the dealer tells you it can't be done, that's bunk. The programmer that can do this at the dealership is called IDS. Try to find an independently owned repair shop who has one or tip a mechanic at the dealership to do it for you.
Here's the steps:
1. Followed path: Module Programming> Programmable Parameters>
Tire Pressure Monitoring System
2. You will see some warning pop-ups that you just click "OK" and/or "YES" through.
3.Then set the pressure for front and rear. Every setting is available.
Thanks Sneaky. That's very helpful.
Old Feb 1, 2012 | 10:38 PM
Sgt93's Avatar
Sgt93
Or...... Buy an H&S.
bushpilot
May 10, 2017 10:06 AM
richhrub
Feb 19, 2014 06:37 AM
admorris
Nov 30, 2011 09:59 PM
LaredoF350
Apr 12, 2009 07:32 PM
zr440man
Jun 30, 2005 09:49 PM
