starting problems and P1405
Old Jan 29, 2012 | 05:47 PM
hooked2's Avatar
hooked2
2000 Expedition 5.4L (127K miles) - recently had misfire codes P0306 & P0307 so, replaced all plugs, #'s 6 & 7 coils, and all boots (had to remove fuel rail on cyl's 5 - 8). afterward, started ok for a few starts but then had trouble. sometimes it starts on 1st key turn but other times, engine acts like it wants to start on 1st turn but then dies. then it takes at least 5, 6, sometimes 10 or more attempts before i can get it to start. still have intermittent starting problems and now i'm getting P1405. i know the P1405 is related to DPFE / EGR issues but can this code cause starting problems or might the starting issues be fuel pump related?
Old Jan 29, 2012 | 06:19 PM
critterf1's Avatar
critterf1
Did you happen to not connect the DPFE hoses?
Old Jan 29, 2012 | 06:24 PM
hooked2's Avatar
hooked2
pretty sure i did but will check to make sure and that the hoses aren't cracked or have leaks. can that cause starting problems?
acdc
Apr 16, 2013 10:14 AM
daerhldgs2
1997 - 2003 F150
Sep 5, 2009 12:07 AM
bla1879
S. California Chapter
20
Jun 3, 2009 11:07 AM
DBtoter
1983 - 2012 Ranger & B-Series
Mar 26, 2007 05:22 PM
