Sponsored by: Real Truck
2003 Tranny problems
Old Apr 21, 2003 | 03:54 PM
DougF350's Avatar
DougF350
Unhappy 2003 Tranny problems
I have a 2003 F350SD with the 6L and 5 speed auto trans. It has under 800 miles on it and the tow / haul system is acting strange. At 600 miles I started the truck and found the tow / haul light on (orange light on colum shifter) Pressed the button to turn it to normal operation. now the "ON" light won't come on, when ever I start the truck it is in tow / haul mode. I can switch it back to normal mode if I press the button. When I go over a large bump (railway crossing) it will jump back to tow / haul. The "ON" light does not work at all...... Anybody have an ideas????
I am taking it to the dealer on Thurday... BUT... They said they have not yet had to work on a new trans.... This scares me!!!!
Thanks, DG
Old Apr 21, 2003 | 08:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It isn't a transmission problem. It's either a wiring problem or a bad computer.
Old Apr 21, 2003 | 10:12 PM
DougF350's Avatar
DougF350
Smile 2003 Tranny problems
Thanks for your comments Mark, by the looks of your profile I would guess you might have an idea about the new 5 speed .
Would you have any sugguestions for me to pass onto the dealership?? They have yet to work on the new trans. This makes me uneasy.
When the first problem happened I started the truck, the tow / haul light was on. I turned it off by pressing the button. The light went off. It then came back on, so I pressed it again. the "ON" light flickered three or four times then nothing. Now when I start the truck it comes on in tow/haul mode (with no "ON" light). I can put it in normal mode by pressing the button. If I put the truck into park it jumps back to tow/haul (no "ON" light) the same thing happens if I go over bumps.
Thanks for your time.
Doug Garritty
Old Apr 22, 2003 | 12:25 PM
Mark Kovalsky
They don't need to work on the transmission. It's a wiring or a switch problem. They have probably worked on one like that before. The wiring is not all new.
