It means if the EGR cooler ruptures, it can dump coolant into the intake...water (coolant) can't compress like air in the cylinders. Which means the engine won't turn over. It can also cause all kinds of damage to the engine. That's why a delta of 33F is scary. Get it fixed or quit driving the truck before things get really expensive
If I was you I would get some VC-9 and do a really thuro flush pull the thermostat out flush a couple times with water then add the VC-9 2bottles of it and set to high idel for an hour thats like 1100 rpms. Flush it clean then replace that oil cooler
OK well I have been doing a lot of research and I think im going to give it a good flush and put a new oil cooler and egr cooler. It looks like some work but not undoable... any suggestions as to the best and cheapest place to get what I need?
OK another question should I do a egr delete or keep it? I found a kit with the oil cooler sinister egr delete and all gasketts and rings for 665.00 is that a fair price?
I see you're in Arizona. If you have to get smog tested then an EGR delete is NOT in your future. IMHO $665 is too high. An oil cooler kit can be purchased for <$250 shipped to the house and it comes with all the necessary gaskets. BPD cooler is $350 plus shipping. You MIGHT need a turbo install gasket kit for $10.
I can not find a oil cooler for less than 300. Am I looking in the wrong place. And yes I have been told to do the egr cooler at the same time, on that note can anyone tell me why I need to change the egr if there is nothing wrong with it. Thanks
if ur doing the oil cooler, ford recommends doing the egr cooler as well, cos the gunk tat killed ur oil cooler might still be lurking around and might also kill ur egr cooler in the future as well.
