Modular V10 (6.8l)
Hesitation/Cut Out when Accelerating
Old Jan 29, 2012 | 09:35 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
That is what we are all here for. Now take that knowledge and share it with others when you get the opportunity. You will still want to check for codes. Enjoy the ride.
Old Jan 29, 2012 | 10:08 PM
4mcrue's Avatar
4mcrue
No problem, that's what the forums are for! I am not an expert, but I like to give advice from personal experience. I would run it over to o'reily's and borrow their scanner and check for codes if you want to still do that. Keep us posted
Old Jan 30, 2012 | 10:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Another success story
Old Dec 28, 2020 | 11:44 PM
Scott Fox's Avatar
Scott Fox
Originally Posted by TrdLtly
Agreed. Check for codes first. Fuel filter likely. How clean is your MAF sensor?
I had a very similar problem.
Solved it yesterday by replacing spark plugs.
Every plug had discoloration where the ceramic meets the steel threaded barrel.
I had read that this is not that uncommon at and after 50k.
Old Dec 29, 2020 | 04:12 AM
JWA's Avatar
JWA
The most important aspect of spark plugs in the Modular Motors is their accumulated mileage and the condition of the electrodes. You don't mention your's. It would seem if that plug change "cured" your own problems they were well past needing changed.
Boots also play a big part to smooth running V10 gasoline engines, all Modular Motors in fact Some claim running these plugs to 100K and above is okay---I say they've done their intended job at 50K.
Unless the discoloration you mention is black or sooty its not uncommon nor a huge problem.
jd_boggs
1983 - 2012 Ranger & B-Series
Feb 6, 2010 11:52 AM
psu1xj
Aug 30, 2007 07:27 AM
crookster
May 2, 2007 02:25 PM
msgntsu
Apr 25, 2006 01:56 PM
OAGES
Feb 20, 2004 09:38 AM
