centurion fuel issues
Old Jan 28, 2012 | 01:02 PM
oreocreaming's Avatar
oreocreaming
OKAY, so I'm guessing that its my fuel pump. Second opinion is always wanted/welcomed.
I've got a 1992 centurion bronco. 5.8l, 4x4 e4od. Single tank, no fuel pressure from the fuel rail. I started at the self test plug, key on, 1 second ground then off. stays lit while cranking so thats good. Second, tested the relay just to double check its not messed up and its good. Next i ran to the spliced plug for the fuel pump (thanks centurion for not doing better work) and plug side colors goes as follows. Yellow:ground (weak though) pink with stripe:grounded til key on, one second then ground again. hot while cranking as well so guessing thats teh lead from the relay. black:grounded gray:grounded.
So, thinking my fuel pump just took a poo?
*P.S. Also checked the inertia switch and that wasn't tripped.
Old Jan 29, 2012 | 12:12 PM
oreocreaming
wow, all these views and nobody has any input?
Old Jan 29, 2012 | 12:53 PM
GNR22's Avatar
GNR22
You should be able to hear if your fuel pump is running. It'll make a whining type noise. otherwise maybe the relay on the fender is junk.
Old Jan 29, 2012 | 02:47 PM
tjc transport's Avatar
tjc transport
i ain't rite
the only real way to know if it is the pump or not is to disconnect the wires at the tank and test for power there. if you have power, the pump is dead.
Old Jan 29, 2012 | 05:40 PM
subford's Avatar
subford
The Yellow wire is for the gauge, not ground.
Old Jan 29, 2012 | 10:23 PM
oreocreaming
i didnt say it was THE ground, just reporting on the wire itself, being grounded or hot. yellow and gray are both for the gauge, black and pink are hot and ground for the pump.
EconolineFan
General Automotive Discussion
May 10, 2019 10:39 PM
fordtrucksforever
1978 - 1996 Big Bronco
Feb 21, 2010 07:36 PM
dblack45887
Sep 21, 2009 07:46 AM
justseggy
Nov 17, 2005 11:27 AM
89bronc
Jan 28, 2004 11:54 AM
