Broke down. Help :(
Old Jan 27, 2012 | 09:20 PM
Fydaman's Avatar
Fydaman
Broke down. Help :(
Ok. Installed my new stereo in the glove box today.
Decided to drived around to listen to new sound. Running perfect Then BOOM
Died as i was driving and could not get it started again. I tried forever but nothing... Its turning.. and i can hear fuel in the carb.
Leads me to believe its a spark problem
Where should i start? its on the side of the road and will be tackling this in the morning.
Old Jan 27, 2012 | 11:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, what year ('75?) and what ignition? (points or electronic)
First, check to see if you do or don't have spark. Pull the coil wire out of the distributor cap and hold it about a 1/4" away from a good ground. Have someone crank the engine over. You should see a strong, blue white spark. If you do then the ignition itself is okay. If there is no spark, then we need to know what type of igniton to properly trouble shoot it.
Old Jan 28, 2012 | 12:09 AM
Sleepy445FE's Avatar
Sleepy445FE
If you do have spark, then pull the cap on the distributor and make sure the rotor still spins when you turn it over. If it doesn't then you've probably snapped the shear pin in it. I've done the same thing. Cruising along just fine and.....BOOM! I was like Fuuuuuu.... Turns out it was only the shear pin failing causing a backfire. Easy to replace, just make sure you find all the pieces of the pin.
Old Jan 28, 2012 | 02:08 AM
cj06's Avatar
cj06
BOOM , probably a backfire !
check what the others have said about spark !
and could be your timing chain jumped !
Old Jan 28, 2012 | 02:12 AM
cj06's Avatar
cj06
BOOM , PROBABLY A BACKFIRE !
CHECK FOR SPARK LIKE OTHERS HAVE SAID !
AND COULD BE THE TIMING CHAIN JUMPED !
Old Jan 28, 2012 | 05:20 AM
Fydaman's Avatar
Fydaman
It did backfire.. And had been lately. I just got the truck..
Old Jan 28, 2012 | 08:46 AM
77393's Avatar
77393
Usually when you have one backfiring its running lean or the timing is out of whack on it. Pull the cap and turn it over to see if the rotor is even turning.
Old Jan 28, 2012 | 12:37 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by cj06
THE TIMING CHAIN JUMPED!
That's my guess as well. (or the ICM gave up the ghost).
Old Jan 28, 2012 | 12:59 PM
justforkicks's Avatar
justforkicks
did the truck sit for a while before you bought it? mine did something similar, turned out a large chunk of debris from the fuel system got in the float bowl and plugged up the jets. i was able to limp it home, but it would run on 6 cyl, then 4, then 3, then back to 4, then it would run on 8 for a little bit, then it would run on 6 again, etc.
Old Jan 28, 2012 | 08:33 PM
Fydaman's Avatar
Fydaman
UPDATE: Went to go mess with the truck to see what was up.
I have spark. And compression.
Turns out this 4barrel Holley carb is being a PITA
The carb is flooding like crazy without any throttle. Just dumping fuel..
Floats are probably sticking.. or something weird.
Im going to take it in and get it tuned, cleaned and rebuilt.
Unless there is another recommendation
Ben's 77
Sep 11, 2017 02:49 PM
Scoop531
Aug 9, 2015 01:00 PM
THAT.GUY
19
Jan 12, 2013 03:00 PM
jefferias
Oct 6, 2004 11:19 AM
airharley
Aug 6, 2002 03:49 PM
