Overdrive Transmission Issues!
Old Jan 26, 2012 | 05:17 PM
silsbec's Avatar
silsbec
Cool Overdrive Transmission Issues!
So when I go to get on the freeway and hit 55 my 97 F150 will rev up to 4 RPMs but will only get to 60. Even getting to 60 is hard on my truck.
Not only will it jump to 4 RPMs, but the truck will shift as I try to get to 70 (which to do i have to pretty much press the pedal all the way down) but wont get any higher than 60.
So I am clearly assuming it is the Overdrive system in the trans just not sure if it neeeds to be reworked or a whole new trans should be installed. The truck does have fluid and all that is fine, but it does need a tune up soon...but this is too big a problem for just a tune up fix.
Erikh425
Jan 3, 2010 05:07 PM
gdw3138
Bronco II
Sep 25, 2007 03:16 PM
rangerford
Dec 13, 2005 07:51 AM
