6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
OIL SLUDGE
Old 01-26-2012, 10:48 AM
B&B TOWING's Avatar
B&B TOWING
B&B TOWING is offline
OIL SLUDGE
HI every one has anybody had a sludge problum my 08 F450 6.4 only has 35k on it I have had a antfreeze problum since day one been at the dealer they replace the rad hoses and tank now the trunk runs pertty bad so I sent it to the dealer and ther telling me it's pretty sludged up and it needs a motor and they are not covering it and they want 15k to replace it telling me poor maintence which is bs can any one help PLEASE
Old 01-26-2012, 11:32 AM
senix's Avatar
senix
senix is offline
Received 1,539 Likes on 1,096 Posts
I would gather all reciepts for maintance esp for oil changes. You know you should be doing them every 5K right? Or XX hours according to the maintance.
I would also advise you call Ford cust svc for fleet and speak with them as well.
Sounds to me like anti freeze got into your oil and created the problem. I think you need to point that out as well. Get them to pull the front cover off and check for cavitation. Have camera and be there.
Old 01-26-2012, 12:00 PM
B&B TOWING's Avatar
B&B TOWING
I did do all the oil change around five thousand miles may not all were exact on 5k but pretty close and I did call ford and they called the dealer while I was still on the phone and denied the claim and I did try to explain to them about the antifreez and seens like they dont care
Old 01-26-2012, 12:24 PM
senix's Avatar
senix
senix is offline
Call these guys:
https://www.fleet.ford.com/contacts/...ion_center.asp
I assume this is a business tow truck so I'd think you would have purchased thru fleet.
Old 01-26-2012, 03:16 PM
blackeyed1's Avatar
blackeyed1
blackeyed1 is offline
Seems like they have all the excuses down pat in their play books.
Old 01-26-2012, 05:42 PM
Bounds-Electric's Avatar
Bounds-Electric
Bounds-Electric is offline
FORD USER
What oil are you using (is it a diesel spec.) if not it will sludge and other problems , are you using Ford filters, are you changing filters every time you change oil, are you doing all city driving? Why are they saying motor?
Old 01-27-2012, 07:46 AM
B&B TOWING's Avatar
B&B TOWING
yes I use diesel oil 15-40 and only ford filters they said that the engine is so gum up like tar the only thing I can think of is the antifreeze is going to the oil in some way
Old 01-27-2012, 07:50 AM
senix's Avatar
senix
senix is offline
Have them pull the front cover and check for caviation. You want to see it for yourself. Be there when they do it.
Old 01-27-2012, 07:53 AM
B&B TOWING's Avatar
B&B TOWING
do u think the antifreeze entering thru the cover
Old 01-27-2012, 07:56 AM
senix's Avatar
senix
senix is offline
Thru the cover or EGR coolers is the common locations. EGR valve if you have the old style.
Old 01-27-2012, 08:01 AM
B&B TOWING's Avatar
B&B TOWING
this is 6.4 new style the coolers are located on the front of the motor not on the intake like 6.0 style I am going to call ford about the front cover to see what they say about it and I want to thank you for help and info
TrikeDawg
2017+ Super Duty
38
07-29-2019 01:09 PM
StanleyZ
08-04-2010 11:50 AM
caddy
Oil & Lubrication
47
10-10-2009 11:02 PM
jones construction
1999 to 2016 Super Duty
04-06-2008 03:42 PM
TruckLarry
Oil & Lubrication
17
12-31-2002 09:02 AM
Quick Reply: OIL SLUDGE
