So for those that have the X3 (I'm looking at the SF3 in particular), how does it handle the codes when the EGR is blocked off? The info on their web site says it'll "read/clear" codes. Would I have to clear the code each time I start the truck?
Anybody have an SCT tuner that will not load?? Mine gets up to 86% one time and quit...most of the time it is about 25-40%.Even had Mike go thru everything and also SCT tuners in Florida completely delete the program and format the new one from Mike.
CPaulsen,
First, I would suggest calling the dealer you got the tuner from.
Then if that's not feasible, call sct or post a question to them via their contac us @ SCT Performance - More Power! Less Fuel!...
since mine never did that, can't assist with what it may be.... other than your trucks battery is not up to the task ?
Do you turn EVERYTHING off when tuning other than the key on and no engine running?
what type engine, year, sct tuner ?
has it ever loaded correctly ?
what version of the flasher's software do you have ?
is the tune in the tuner for YOUR truck, not your buddies truck that's just like it
CPaulsen,
Just got it....brand new! Talked to Mike and SCT also. They deleted the programming out of it...formatted the tuner and installed the newest up to date software.
Brand new battery. Even hooked up a 6 amp charger also per Mike.....2001 F350 V-10. Everything was turned off. Just waiting for a replacement now to see if that works. Got it to load up to 86% one time...couple of times to 35-40%...most of the time it was 15-18% then it would quit.
