Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Misfire
Old Jan 25, 2012 | 09:53 PM
Austin J.'s Avatar
Austin J.
Misfire
I have a 2001 Ford Escape v6 and it is reading misfire on #4 and #6. It only happens intermittently. It already has the cats cut out and it has a brand new EGR so they aren't clogged. I have seen where it might be the PCM, but it had the recall work done on it many years ago. How do I prevent this from occurring again?
Old Jan 26, 2012 | 07:55 AM
tomw's Avatar
tomw
Pull the COP's and check for oil in the plug area. Oil is a dielectric, but with contaminants, it becomes a partial conductor. The plugs can fire to the head rather than inside the combustion chamber if there is oil there.
The COP units can also fail. The plugs need to be replaced or re-gapped over time, have you done that? If the gap is too large, they misfire, and can take out a COP {$$$$} or a computer {$$$$$$$$$$$}. Plugs are relatively cheap, around $2.50 each.
If there is oil, you can replace the O-rings that seal the plug tube, and may solve the problem.
tom
Old Jan 26, 2012 | 06:28 PM
Austin J.'s Avatar
Austin J.
I just checked for oil and there was none and the plugs have been replaced recently.
Old Jan 27, 2012 | 06:24 AM
tomw's Avatar
tomw
Several other things cause misfire. Injectors clogged or leaky, fuel pressure too low or too high, leaky valves or rings, and the ignition system including the COP and the boot on the COP. The wires to the ECM could also be intermittent if they have been flexed too many times or are corroded, or even the ECM could be failing.
You can replace or rotate the COP and see if the misfire follows, check the resistance on the wires to the ECM, inspect the boots for indication of spark eating a hole in the material, check the fuel pressure {pump and/or regulator} and delivery volume, though it would cause misfire in the 'weakest' cylinder, and maybe all. And check the compression.
Sounds like fun, no?
tom
Old Jan 27, 2012 | 03:20 PM
Austin J.'s Avatar
Austin J.
At least when I figure out the problem, any parts will be free, due to wrecked escape siting in the yard.
Old Jan 27, 2012 | 10:38 PM
bmuhlbach's Avatar
bmuhlbach
lower intake gaskets could be bad.
Old Jan 30, 2012 | 05:03 PM
daveya48187's Avatar
daveya48187
misfire
I had the same problem, the spark plugs weren't getting the high voltage, replaced the faulty ignition coil and boot on that particular cylinder. As cars get older the high voltage insulator break down. Found they're $65 each at Orileys but found a wholesaler on line and got one in the mail for $16.00. website: https://globalautomotiveofmiami.com/
dpeterson3
1983 - 2012 Ranger & B-Series
37
May 27, 2019 11:38 AM
Caen Terry Viso
Jan 7, 2016 07:50 AM
snowbrdjnky
Jun 6, 2013 10:37 PM
borg_99
Dec 8, 2010 04:45 PM
crescentwrencher
Oct 2, 2009 06:56 AM
