98 4.0 Interiment Missfire
For about a year now, my ranger has had an intermittent misfire on cylinder 6 (sometimes sets code P0306). I have code P0455 set, but I believe this is unrelated. By intermittent, I mean that it will start rough, drive for a mile, run fine, get on the interstate, misfire for a while, and then run fine again. Happens in all weather, does not seem to matter if then engine is warm or cold, and is not speed dependent (might happen at idle or going down the road). I have not had time to seriously troubleshoot it until now, but I am at a loss. (warning, long story ahead)
About a year ago, I had a miss on cylinder 6. I had replaced a failed fuel pump a couple of months before, and the truck had seemed to be low on power. The last time this occurred, I had had a snotty injector. I pulled al 6, cleaned, and pressure tested them with 90lbs of air (forward and backward). Some junk came out, and one was slightly snotty. After cleaning, it seemed fine. I used a tube full of carb cleaner connected to an air hose as a cleaning method. The truck seemed to run better afterward. I did have to replace the rubber seals twice as I buggered them up putting them on and it leaked, but I eventually got it running correct again.
Fast forward a couple of months, and my misfire comes back. Since I could not remember when the last plug change had been (at least a couple of years), I decided to replace all 6 plugs. The problem went away a couple of days, but then came back. I used bosh plugs.
Since I could also not remember the last time I had changed plug wires, I went ahead and replaced them. When changing them, I decided to pull #6 plug to check it. When I did, it broke off at the base during removal. Due to how it broke, I believe this was a factory defect. Thinking I found the problem, I replaced the plug with a spare I had from the same lot as the original, and continued replacing the plug wires. The problem went away for a few days and came back.
Now, being annoyed that the misfire seemed the come and go, I suspected the replacement plug was bad since it was from the same lot. When I pulled it, it had some surface cracks near its base. Since I had read Bosh plugs are not the best, I got an NGK as a replacement thinking that they are hotter and might help to burn the junk that may have accumulate in the cylinder. The replacement plug helped, but did not fix the problem this time.
At the time, I had no more time to look at it, so I let it go for a couple of months since it was not bad enough to be un-drivable and the the CEL was not flashing. Got time to look into it about a month ago. Did a compression check on #5 and #6 cylinders (#5 had started misfiring slightly, but was just a plug that I'd forgotten to change the first time). I had both plugs removed and both cylinders ran up to and held slightly above 120lbs. I know this seems a bit low, but I did replace the heads with aftermarket ones right after I got the truck due to the cracked head problem. Since both matched each other and both held pressure for at least 3 minutes, I am going to assume the lower pressure is due to the aftermarket heads. This lea me to believe that maybe when I had the broken plug, it took part of the coil pack with it. In addition, the last time the coil pack was changed, a shop did it without asking me, so I did not know what kind was on it. Replaced the coil pack and gave it another round of NGK plugs to make sure all cylinders are the same. The problem went away for about 2 days and then came back. Misfire #6 cylinder (1.67% rate according to mode 6).
At this point, the injectors should be clean, the ignition system is new, and I have compression. I have attached a couple of pictures of what the #6 plug looks like when I pull it. One other thing to note is that the threads of the plug always seem to be a bit oily when I pull it. Not sure i that is related or not, but none of the others do that. I am not sure where to look next as all the normal misfire causes seem to be ruled out.
Plug Pics
If you find a seal problem & fix it, maybe consider removing the #6 spark plug & giving the cylinder a good overnight soaking with a couple ounces of Marvel Oil to free up the rings.
Then add a 20oz dose of Techron Concentrate Plus at the pump before filling (so to get good mixing) with Chevron, Texaco, CalTex or now Shell, all of which already have some PEA in their fuel ad pack, so the extra 1oz/gal Techron will raise the treat rate 10X above pump gas alone, so can often tidy up the fuel injectors, intake valves, piston crowns & combustion chambers in one dose, if we'll run most of the treated tank out before refilling & do some daily rpm run up's to 3500 for a mile or two to blow out loosened deposits.
If a follow up #6 plug inspection shows a clean plug, call it fixed for now. If it looks better but not as good as you'd like, repeat the Techron dose at the pump on the next refill & repeat the daily high rpm blow it out routine & let us know how it goes.
Doesn't matter now I suppose, as something is going on with cylinder #6 if only its spark plug is fouled, so question is What is the root cause?
After looking at the plug deposit photos again & noticing they look kinda Dry, not really oily, maybe #6 fuel injector is defective, or is dirty & has a really bad runny nose & #6 cyl is running really Rich. So hook up your ELM scan tool & running FORScan or the like diagnostic software on the viewing device of your choice & have it take a look at the short & long term fuel trim on the drivers side cyl bank,(Bank-2), compared to Bank-1 passenger side & see if it'll show any fuel trim corruption, or control problems with Bank-2 in which cyl-6 resides? Post up the fuel trim Numbers & any trouble code clues the scan tool finds.
If you don't have a ELM, or can't borrow one, hook up a fuel pressure gauge to the under hood fuel rail Schrader valve test port & see if fuel pressure is in spec & that it doesn't quickly bleed off after the engine is shut down.
If you can't do that, if its been a while since you changed the oil, pull the dipstick & give it a sniff to see if it reeks of gasoline. Or maybe after it sits for a spell after driving & cools down some, remove #6 spark plug & give it a sniff to see if it reeks or is damp with fuel. If so, remove the #6 fuel injector for inspection & or cleaning, or replacement if it looks to need it.
A bunch more thoughts for consideration, let us know what you find.
If ok, pull the fuel injector & inspect for signs of a runny nose.
If no joy there, maybe put the #6 cylinder piston oil control ring on the suspect list as suggested previously. Maybe consider warming the engine a little & performing a overnight piston soak with something like a couple table spoons of Marvel Oil or the like for #6.cylinder & see if you can get a positive result.
If you have, or can come by a fiber optic probe, remove #6 spark plug & have a look around the #6 combustion chamber for clues & let us know what you find.
More thoughts for consideration.
Lifters aren't going to cause too much oil in #6 cylinder. Worn valve guides, leaking stem seals or a mucked up piston oil control ring can.
