No spark?
Old Jan 25, 2012 | 05:08 PM
Rat77's Avatar
Rat77
No spark?
Here is my issue, my 1977 F150 with 400, auto. Trucks been sitting awhile and before I fixed fuel delivery it would start and run for a second before the fuel went away(poured some gas down the carb). After I have sorted out the not getting any fuel issue ( rebuilt carb, new filter and new fuel pump). Now it cranks over but won't fire. It sounds like no spark. Check power to the little horse shoe clip on coil and there was power. But no spark from coil. Dead coil? or where do I need to start looking?
Old Jan 25, 2012 | 05:48 PM
critterf1's Avatar
critterf1
While cranking check negative side of coil with test light, it should flash. If it doesn't, I would be looking at the pick-up assembly.
Old Jan 25, 2012 | 06:41 PM
Rat77's Avatar
Rat77
I am using a multi meter what readings should I see?
Old Jan 26, 2012 | 06:00 AM
JWA's Avatar
JWA
If you're using a DVM it typically won't or can't register quickly enough to measure the pulses you want to see----the test light would.
Old Jan 26, 2012 | 06:55 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The pickup coil in distributor should read 400-800 ohms across orange and purple. Either one to black should read greater than 70K ohms. Coil should read .4-1.6 ohms across pos and neg, either one to output post 7700-10,500 ohms. This is for the stock Duraspark ignition.
Pappee
Jan 11, 2018 04:39 PM
OldGoldie
32
Jan 17, 2017 08:28 PM
janvan
Aug 31, 2011 08:53 PM
Fessik
Apr 21, 2011 07:02 PM
JSPULLER
13
Oct 27, 2004 08:15 AM
