Sponsored by: Auxito
Headlight Replacement Question??
Old Jan 4, 2007 | 12:20 PM
Fordfrog206's Avatar
Fordfrog206
Gentlemen, I usually lurk around in the 04-07 forum however a friend of mine has a question I am sure you can answer.. Here it goes..
Do they make clear lens headlights as replacements for a 97 Ford F-150 XLT Supercab..
Because his are becoming foggy or getting cloudy and he cant figure out how to get them clean. Really appreciate the advice and thanks in advance!!
Old Jan 4, 2007 | 12:29 PM
thehawk789's Avatar
thehawk789
the fogging is a common problem with older cars and trucks, they get moisture in there and it cant get out. The headlights are supposed to be sealed up.
He could try removing them and cleaing them out, otherwise even used replacements will last for a while and still look nice. There are some aftermarket headlights out there that are made to be brighter and clearer. Check ebay for headlights.
Old Jan 4, 2007 | 12:50 PM
galaxie641's Avatar
galaxie641
There may not be any for his truck, depends when it was built. If it is a very early '97 built in 5/6/7 of '96 the header panel is different and the normal headlights and corners don't bolt in the same way. If he has a later build be will be fine. I have a set of Depo headlights and corners and love them.
Old Jan 4, 2007 | 01:10 PM
jackeduptruck99's Avatar
jackeduptruck99
i have a 97' and i went to the lightning style headlights, it was a pretty easy swap, i just had to take my sawzall and cut the hole a little bigger to make room for the extra passing light that comes out of the back of the headlight. i couldn't beleive how much better and updated it made the truck look. i bought the headlights on ebay for $200 and it came with all the new wiring harnesses. easily one of the best upgrades i've ever done for my truck, highly recommend.
Old Jan 6, 2007 | 09:10 AM
triton54's Avatar
triton54
they make a cleaning kit for those fogged up lights costs about $12 at pep boys, supposed to work well but $12 is cheaper than new lights.....may want to give that method a try before moving deeper into the wallet
