Requires lengthy cranking before it will start HELP !!
My 91 (bronco) with the original 351 has developed a hard starting issue over the past months.
To get it started now, I turn the key and crank the engine for several seconds(does not even fire). Then I crank for about 5 seconds and it slowly catches and starts.
I remember in the past, much like my 90 mustang 302, the thing would start so quickly, you barely bump the key and its running.
In addition to the current situation, about a month ago, I was struggling with this starting issuse, it finally refused to start no matter how long I cranked it. I looked at the dist cap and rotor and they looked worn, replaced them, and it started but again with the long cranking.
Where am I with this? Coil? I installed an MSD coil several years ago.
What else could it be?
No, tried many times, waiting to crank until after the pumps stops make no difference.
As afr as 2 pumps go, you got me. If it were a few pressure problem, I don't understand why it runs so strong at WOT.
I wish I had a fuel pressure gauge though.
I found this:
https://www.ford-trucks.com/forums/1...ing-issue.html
This sounds just like my issue, so I will test the ECT and ACT.
Does anyone have some pics to show where these sensors are located?
Matt1967
01-26-2012 12:16 PM
cajun1965
08-01-2007 11:42 AM
mikemustang289
20
10-07-2006 05:06 PM
JBronco
1978 - 1996 Big Bronco
07-17-2003 10:51 PM
