Rear wheel hub
Old Jan 24, 2012 | 09:19 PM
Bootzz711's Avatar
Bootzz711
Rear wheel hub
Yeah got one I want to change cuz it's got a crack in it and can't find one
Are the bearings pressed into it or anything or can I get one and buy new bearings and seals?
Old Jan 24, 2012 | 09:20 PM
Bootzz711's Avatar
Bootzz711
O sorry
It's a rear with 3" drum brakes on a 1992 f250 4x4
Old Jan 26, 2012 | 06:16 PM
Bootzz711's Avatar
Bootzz711
Cmon guys somebodys got to know
Old Jan 27, 2012 | 01:29 PM
rla2005's Avatar
rla2005
The bearings are not pressed in, they can easily be removed, serviced and re-installed as well as replaced with new bearings.. Very similar to a front hub.
Some good photos in this write-up from another forum: Sterling 10.25 rebuild - FSB Forums
Old Jan 27, 2012 | 01:38 PM
andym's Avatar
andym
Get one from a junkyard. Should be pretty cheap. Then you just clean it up, install new bearings, races, and seals and you're good to go. You will need a special socket for the spindle nut. You should be able to get one at Napa or a good auto parts store.
Old Jan 27, 2012 | 07:36 PM
Bootzz711's Avatar
Bootzz711
Ok thanks guys
That's what I was hoping I could do
And I have a socket
Pwrstrkd"X"
Apr 25, 2007 08:32 PM
jeepster1272
Feb 9, 2005 11:00 PM
waldo48
Feb 15, 2004 07:33 AM
