front wheel hub assembly problems.[bearings shot]?
i think my bearings have gone bad in my front wheel hub assembly.anyone/everyone had this problem?psd 4x4 7.3.automatic trans.1999.any and all help or advice relating to this problem woukd be greatly appreciated. im going to fix /change bearings myself and would welcome any ideas regarding my chore ahead of me.also,any website that might make it easier or better as for as diagrams.thanx yall,waldo
johnram1
How long have you had the sound? What changes if any occurred prior to the sound? Does it occur at the same speed? Pull the front tires and check vertical play in the front assembly. Chances are good its your hub which is causing your caliper to constantly ride the disk on one edge. If this is the case, the hub will go any minute now. If it's not the hub, I had my drivers side brake semi-lock which made a humming sound.
Items to try IMO would be brake pads
