Go around to threads and say "Great Work!" until you have over 25 posts. Then you can click on the name of the person you want to send it to and it will give you the option too send so and so a private message.
You could also post on this thread until you have enough. Run this thread up then Ctubutis can delete it.
What can happen is, the thread can be edited (posts deleted (which will reduce the OPs post count)) or it can be deleted in its entirety.
The offending author can then be served with either a Warning or an Infraction.
A warning contains 0 points and is just a friendly warning, whereas an infraction is worth a certain number of points; accumulate enough in a certain amount of time and you can lose your posting privileges.
Just like a driver's license.
Both warnings & infractions are valid for a set amount of time and expire after a while.
Well thanks again for the comments. I have a project truck going on so I have many more post to go!
Cool!
Hey, if you're gonna be here for a while, do me a favor and go HERE and finish filling out your profile so people can see where you're at with each post, OK?
The part that is pertinant to this discussion is the following
Originally Posted by FTE guidelines
2. Personal Conduct . Post language and material suitable for the home or office. Do not post foul language, racial epithets or sexually explicit content in any form. Personal attacks will not be tolerated. Posting for the purpose of gaining access to additional features of the site is not allowed.
