Does Pertronix make a module for a 55 239 ?
Old Jan 26, 2012 | 10:40 AM
Y-Blockhead's Avatar
Y-Blockhead
Originally Posted by HT32BSX115
I'll second that. I had a Pertronix setup on my 12v 55 239 engine.
It worked fine. I couldn't tell much difference between it and the points I removed however.....
I didn't install a Pertronix for performance but for maintenance (unless you consider lack of maintenance better performance?). I do check my cap and rotor occasionally. In fact I would recommend users check their distributor. I actually had a distributor shaft bushing go bad and was surprised that the engine was still running (and pretty good) and the Pertronix wasn't damaged. I did replace the magnetic sleeve as it was beat up pretty bad but could have still been used. Try that with points.
I did notice that my Ranchwagon started easier but that may be due to using the Pertronix to trigger a MSD box. Whole different ballgame there.
Old Jan 26, 2012 | 08:10 PM
baddad457's Avatar
baddad457
Originally Posted by Beechkid
You are absolutely right....and was my point (no tangent)....for anyone to say that points are not reliable, etc, or to say that e-boxes by themselves are better is just not reality if you are comparing good quality to good quality, each has benefit, but to think because of marketing hype that e-boxes by themselves will "Boost" performance by some unscientific miracle, well that is just wasting $.......whether someone wants points/e-box because they want it is fine, both work very, very well in both street & racing applcations.
When I see someone claiming I am on a rant, it reminds me of the "Cold Air" scam............which I can tell yu dating back to 1997 I have been blasted by both K&N reps and FTE members, even though engineers from Ford documented in writing the issues with my new car (90 days old) with the K&N filter......and now that Testand Corporation conducted an ISO standards test on automotive air filters (which from a flow standpoint verified absolutlely the the other half of the issues with these type filters) it's funny that they have all "dissappeared".
And now you're off on another rant (tangent)
Old Mar 10, 2012 | 07:32 PM
mn1500's Avatar
mn1500
Look up pertronix on the net and call them, they will sell you the correct unit. It does not matter to them if it is 6v or 12v, positive or negative ground. You just need to tell them in advance so they setup your unit in advance.
Amphenol
15
Jul 12, 2011 02:54 PM
4x4lugnut
Electrical Systems/Wiring
May 10, 2011 09:12 PM
grego
May 9, 2010 09:35 AM
quentrm250
21
Nov 5, 2003 07:24 AM
spacecoast
Oct 22, 2002 07:26 PM
