flasher relay buzzing
Old Jan 23, 2012 | 08:47 PM
ridgeseeker's Avatar
ridgeseeker
I have 2003 F250 2wd 7.3 and when my wife started it up this morning she heard a buzzing noise. I located the noise under the dash and it is coming from the flasher relay. when we depress the brake pedal or use the turn signal the noise stops When the brake pedal is released or the turn indicator is back in center the noise comes back.I checked all the lights,none are out and I replaced the flasher relay but the problem did not go away. I also checked my trailer brake actuator and the connectors at the rear bumper. Any ideas as to what the might be the problem? Any help on this would be greatly appreciated.
Old May 9, 2012 | 06:57 PM
HRJoe's Avatar
HRJoe
I have same exact issue. Ideas?
Old May 9, 2012 | 07:15 PM
Tugly's Avatar
Tugly
  1. Flasher or blinker?
  2. Are the flashers off?
  3. Can you swap flasher/blinker relays?
Old May 14, 2012 | 06:26 PM
HRJoe's Avatar
HRJoe
New turn signal assembly (multi function relay) was the fix. Flasher relay is what is buzzing, but the root cause is the turn signal / multi function switch.
1'stonraceday
18
Sep 14, 2015 08:50 AM
flyinnuts
2009 - 2014 F150
19
Sep 11, 2013 10:28 AM
Rusty_S
Electrical Systems/Wiring
Aug 18, 2013 01:30 PM
Stroke'NPower
Oct 26, 2007 06:38 AM
dwetopgun
Jun 30, 2003 11:24 AM
