HELP!!! PLEASE
Old Jan 24, 2012 | 06:47 PM
Potlicker David's Avatar
Potlicker David
Fuel in fuel bowl looks good it is not gelled it is like 35 degrees
Old Jan 24, 2012 | 07:03 PM
Iallwork's Avatar
Iallwork
plug it in if you can find the heater plug end. charge the batteries. cycle through the wait to start light a few times before you try to start it. Probably some bad glow plugs. Like someone said the glow plugs stay on longer than the wait to start light. let us know if you get it going.
Old Jan 24, 2012 | 07:04 PM
madpogue's Avatar
madpogue
Originally Posted by bearhugger
You said you waited until the wts light goes out,you need to wait about 120 seconds,the wts light is just a indicator.
You don't need to wait anywhere near that long. Yes, the glow plugs stay on for up to 120 seconds. But as we all know, the glow plugs are not just for starting the engine.
But yeah, on a really cold day, it's a good idea to leave the key in RUN after the WTS light goes off before starting. Usually another 10 seconds or so will do, but it may take up to 20 seconds after the WTS goes off.
If anyone has to run the glow plugs for the full 120 seconds just to start the truck, they've got bigger problems (probably only a few GPs working, or serious fuel delivery issues).
Originally Posted by wycowboy
Did you check the maxi fuse und the hood? I think it is 22 that runs the idm.. It is also on the same circuit as the fuel bowl heater.. It often goes out in cold whether.
It is indeed fuse 22, but it energizes the PCM, not the IDM. If the OP is getting a WTS, white smoke and tach movement, however, then s/he's delivering fuel and therefore the PCM is energized.
How's the oil level in the HPOP reservoir?
Old Jan 25, 2012 | 09:45 PM
Potlicker David
I just noticed your last line about the HPOP resavoir it is empty what do I do about it.
Old Jan 25, 2012 | 09:52 PM
fordpride's Avatar
fordpride
Refill it and let it sit over night and check it before you try and start it. It could be draining down also extended cranking will also drain it
Old Jan 25, 2012 | 09:53 PM
Action4478's Avatar
Action4478
Change the oil .. most likely you need to replace the LPOP, Injector O rings can also be an issue ...
Old Jan 25, 2012 | 10:09 PM
Action4478's Avatar
Action4478
Extended cranking ? If the LPOP is up to it , that will not be an issue ...Its designed to keep the res full ... So international designed a pump that can't keep up with what was needed .. GMAB....
Old Jan 25, 2012 | 10:54 PM
fordpride's Avatar
fordpride
If you want to correct a persons info then fine correct away but don't be a *** about it Rick
mad_science
Feb 26, 2018 10:46 AM
Dieselgrowl
Jan 9, 2014 10:46 AM
evans213
27
Jan 20, 2011 06:24 AM
prettygt2
Dec 8, 2006 04:23 PM
busakiller2001
Jan 30, 2006 06:06 AM
