Mysterious 390!
Old Jan 22, 2012 | 05:10 PM
mjshagnasty's Avatar
mjshagnasty
Talking Mysterious 390!
Long story short i found water in my oil during my last oil change, so i pulled the "360" out of the highboy to start the tear down and find the culprit. After i pulled everything I decided I would check the stroke for ***** and giggles, turns out I have a 390. so that made my day, and in the process of doing all that i also noticed that the cross hatch from the last honing was still there. Now this truck has been in the family forever, my uncle says he remembered the truck getting a new clutch back in eighth grade and that was 22 years ago. He never remembered the engine getting swapped, I guess that story is lost to history. Doesn't bother me any, all i have to do is re gasket the thing and I'm good as gold
Old Jan 22, 2012 | 05:54 PM
critterf1's Avatar
critterf1
Where was the water leak?
Old Jan 22, 2012 | 06:34 PM
mjshagnasty
It ended up being the timing cover gasket.
Old Jan 23, 2012 | 03:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Now this truck has been in the family forever, my uncle says he remembered the truck getting a new clutch back in eighth grade and that was 22 years ago. He never remembered the engine getting swapped.
The engine code is the 4th digit of the VIN
1968/72 F100/350: A = 240 I-6 / B = 300 I-6 / G = 302 2V (1969/72 F100 only) / H = 390 2V / Y = 360 2V.
390's were not factory installed with 4WD. 1968/76 F100/250 4WD: The only available V8 was the 360, 2V's only offered.
Old Jan 23, 2012 | 06:02 AM
mjshagnasty
I know which is why I was suprised it was a 390
Old Jan 23, 2012 | 09:54 AM
MIKES 68 F100's Avatar
MIKES 68 F100
timing cover gasket ? correct me if i am wrong but water pump sits over timing cover and connects to block at three points- two sides (like chevy) and short hose at top .
Old Jan 23, 2012 | 10:00 AM
MIKES 68 F100
pic
Old Jan 23, 2012 | 10:35 AM
mjshagnasty
Yes but if the gasket was gone leakage from anything such as rain or that little radiator hose leaking could get in there and get into your oil. I'm thinking this is why the front of the engine was so greasy.
Old Jan 23, 2012 | 04:56 PM
NumberDummy
'Short' aka 'little radiator hose' = By-pass hose.
prdjr1
Aug 21, 2017 01:29 PM
mofoco1
Oct 29, 2016 09:14 PM
Dynam1te
Apr 25, 2013 10:10 AM
first71F100
15
Nov 12, 2012 04:06 AM
Dajudge51
Jan 11, 2008 10:03 AM
