Oil in coolant! 1988f350 460cu.
Old Oct 28, 2002 | 07:09 PM
CLC's Avatar
CLC
I have a 1988 f350 with a 460.It has been sitting for a year.When I started driving it again I noticed it was using oil.There are no leaks and no smoke.I checked the plugs and they are dry.So I checked the coolant and it was a little milky.But I'm not sure it's oil?And the oil looks fine just low.
Old Oct 29, 2002 | 11:36 AM
jim henderson's Avatar
jim henderson
After sitting for a year, wouldn't hurt to change the oil, it's cheap. Then keep an eye on the eye and check the dipstick and the oil filler cap. If you see what looks like chocolate moose or sludge on either you might suspect a water leak. More like just condensation.
Good Luck,
Jim Henderson
Old Oct 29, 2002 | 12:26 PM
Competitor1's Avatar
Competitor1
Post Oil in coolant! 1988f350 460cu.
mrplumber
Feb 19, 2012 11:30 AM
stevetford
Oil & Lubrication
Feb 17, 2010 09:10 PM
rhoward
Nov 12, 2009 07:41 PM
jf350
Apr 19, 2007 09:40 PM
CLC
Oil & Lubrication
Dec 3, 2002 09:41 PM
