Antifreeze
Old Jan 22, 2012 | 02:48 PM
78150custom's Avatar
78150custom
Antifreeze
What antifreeze do you guys use in a 300? Mines leaking from somewhere around the waterpump. Gonna see if I can put some in and locate the leak.
Old Jan 22, 2012 | 02:51 PM
fmc400's Avatar
fmc400
MSEE
I use a 50/50 mix of Prestone and water from the garden hose.
I'm assuming you're wanting to add antifreeze because it's dyed, so you can locate a leak? Even if you live in a scorching-hot climate that never freezes, you still should run antifreeze, because about 5% of it is composed of rust inhibitors that are absolutely essential to your block's survival.
Old Jan 22, 2012 | 03:14 PM
78150custom
It's currently not being driven. I want to fix this problem before I bring it too the city. We've been trying to keep it full just to prevent everything from drying out.
Old Jan 23, 2012 | 04:26 PM
7Ford6's Avatar
7Ford6
I recommend using "Distilled Water" mixed with Your Anti-Freeze over the Garden Hose..
Old Jan 23, 2012 | 05:26 PM
BIGT94z's Avatar
BIGT94z
X2. I run prestone mixed with distilled water
Old Jan 23, 2012 | 08:31 PM
fmc400's Avatar
fmc400
MSEE
I'm sure distilled water is probably better, less contaminants that can help to build up garbage over time. But my reasoning at the time was that if I'll drink it, it's probably good enough to go in my 30+ year old truck (not the most sound reasoning I'm sure)
Old Jan 23, 2012 | 09:12 PM
7Ford6's Avatar
7Ford6
I'll drink to that... But it's not to late, lol.....
In older engines to remove some of those minerals that may have built up over time, one can drain the system completely, then refill with, and run on pure distilled water for a week or so, give the pure H20 some time to absorb some of that garden hose up, drain it, then refill with a mixed solution....
Also, for the rest of you, pre-mixed 50/50 solutions sold are pre-blended with distilled water... Check the ingredients on the label....
Old Jan 23, 2012 | 09:40 PM
meborder's Avatar
meborder
no arguements with distilled being better.
the only thing is i always flush them, and i have yet to figgure out how to get all the garden hose water out of the engine.
so i guess i'm another garden hoser .... gotta get that old crappy stuff out some how. I always just flush it till it is clear, then start the engine with the garden hose running through the engine until it is clear again, then shut it off and drain the radiator and refill with 100% antifreeze. start it up until it is at temp and check the strength.
usually this will get me to where it reads -30 to -40, but never less than -20.
if i could figgure out how to run distilled water through the hose to flush it out, i sure would ... but after 15 years or so of doing this ... i kinda just stopped worrying about it.
granny_rocket
Jan 29, 2016 05:04 PM
firstade
Dec 4, 2010 08:39 PM
Rich J
Aug 10, 2009 10:36 PM
profro
May 29, 2007 06:25 PM
95xltmud
Jan 23, 2003 01:37 PM
